cherry bomb vs thrush vs homemade
Old 02-21-2015, 01:21 AM
steve33444's Avatar
steve33444
steve33444 is offline
Which is louder? A thrush glasspack or cherry bomb glasspack?
Also are homemade glasspacks legal? Specifically in Pennsylvania. I probably wouldn't make my own glasspack but I was wondering if they were legal or not. I would want to make one just so I could stuff it with real glass Instead of fiberglass.
Is real glass louder than fiberglass?
Old 02-21-2015, 06:55 AM
ponykilr's Avatar
ponykilr
ponykilr is offline
This "real glass", what exactly are you talking about? Fiberglass wool is the "glass" in glasspack.
Old 02-21-2015, 08:23 AM
1993_f350_2013's Avatar
1993_f350_2013
1993_f350_2013 is offline
Get Some dynomax race bullets. I had true dual straights no cats and it was loud but it didn't really have a tone a was really loud then i added these billets and wow! They're awesome! They give it a lot deeper tone and are pretty loud when you want them to be but you can sneakish around if you need to
Old 02-21-2015, 09:01 AM
dixie460's Avatar
dixie460
dixie460 is offline
Never heard of homemade mufflers being illegal anywhere. Not sure about Pennsy but can't imagine why not. Use whatever you like! But just so you know, if you're trying to get a louder sound and still have factory cats you will be disappointed. You'll need hi flow aftermarket cats before you can be loud because factory cats are unfortunately real good mufflers themselves.
Old 02-21-2015, 09:37 AM
f100beatertruck's Avatar
f100beatertruck
f100beatertruck is offline
It's illegal in Pa to modify the exhaust to make it louder, but I've never heard of it being enforced. You'd only really get problems from inspection mechanics and state police. In fact former case just shop around. Most state police don't want to be bothered so usually not a problem. Local cops might try and give you crap, but it can be challenged because they usually don't have inspection licenses. All state cops do.
Lastly the comment on the stock cats is true. I've run straight pipes and my mustang was still louder and it's not that loud. The truck was painfully quiet with a glasspack on. Lop off the exhaust and see how loud it is first if you have the stock cats.
Old 02-21-2015, 10:23 AM
eakermeld's Avatar
eakermeld
eakermeld is offline
In my experience, home made mufflers rarely sound like you want them to. And on non-turbo'd engines tend to impede flow and kill HP.
Old 02-21-2015, 10:40 AM
steve33444's Avatar
steve33444
The "real" glass would be actual glass. Like from a window
Old 02-21-2015, 10:42 AM
steve33444's Avatar
steve33444
I don't have any cats right now. I cut them off when I put headers on the truck and where I'm at in pa you don't need an emissions test
Old 02-21-2015, 10:43 AM
steve33444's Avatar
steve33444
Have you made mufflers before? What do most of them sound like?
Old 02-21-2015, 10:45 AM
eakermeld's Avatar
eakermeld
I admire your ambition, but it doesn't work that way. Fiberglass wool is what is inside glasspack mufflers. If you do decide to build a muffler, that material is available to buy.
Old 02-21-2015, 10:48 AM
steve33444's Avatar
steve33444
I know that the glasspacks are made of fiberglass now but wasn't it back in the 60s or 70s that these companies used actual glass before fiberglass? I was pretty sure I read that somewhere but I may be wrong
eakermeld's Avatar
eakermeld
Most of them sounded like a tractor. Some whistled. All droned like crazy. All, to me, sounded like crap. I'm the kind that is always trying to re-invent the wheel but I couldn't do it with a muffler.
Old 02-21-2015, 10:53 AM
eakermeld's Avatar
eakermeld
This is a nice little tidbit of info on glasspacks. Check out the links too.
http://en.wikipedia.org/wiki/Glasspack
steve33444's Avatar
steve33444
What type of muffler did you make? That's how I am always trying to re invent the wheel. I guess I like saying I built it instead of buying it
Old 02-21-2015, 11:01 AM
eakermeld's Avatar
eakermeld
Well casing, driveshaft tubing, round tubes, square tubing, thru pipes that go all the way thru with holes, pipes with baffles, 2 piece thru pipes, thru pipes in 3 pieces ( make an "S" shape), even tried an old freon container once! All with the same result. Lots of weird sounds and no benefits.
Quick Reply: cherry bomb vs thrush vs homemade
