Penny for your thoughts
Old 02-20-2015, 08:13 PM
saauvenshine's Avatar
saauvenshine
saauvenshine is offline
Just got my truck up and running finally and was having some issues with water leaks etc. but got them fixed thanks to you guys on forum. I am still have one problem and need some input. I have a 54 truck with the 239 ohv v8 and I have a pretty good size oil leak after a run the truck for a few minutes. It is leaking out of the crankcase canister out of the tube on the left side of motor. I was wandering what could cause and is there a fix.
Old 02-20-2015, 08:55 PM
Skalywag's Avatar
Skalywag
Skalywag is offline
Are you talking about the road draft tube? Maybe overfilled the oil. check the fluid level. Also make sure you have the right dipstick.
Old 02-20-2015, 10:01 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
What is the overall condition of the engine? Have you done a compression test?
Worn rings can cause excessive blow by.
jmug23
15
01-04-2018 06:16 PM
Barney58F100
10-17-2015 10:13 AM
Still Smoking
2004 - 2008 F150
02-10-2012 11:48 AM
80FlareSide
08-20-2010 11:21 AM
bigblockbronco
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
04-01-2003 07:26 AM
Quick Reply: Penny for your thoughts
