Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Third brake light and cargo light not working
Old 02-20-2015, 06:14 PM
fatforty fatforty is offline
fatforty is starting off with a positive reputation.
Hi, I have a 2008 F350 Super Duty Regular cab long bed 4X4 I have no cargo light and no third Brake light, checked and even replaced bulbs. Still have no lights up top, can anyone tell me what to check or how to fix this? Can I tie the cargo light into the dome light inside without screwing something up? I can't understand why they stopped hooking the cargo light to the dome light but this one seems to be wired separate. Would love to get these lights working again. When I bough t the truck the cargo light didn't work and I thought maybe the bulbs were burnt out, I never checked the brake light I tried to get the cargo light working and that's when I found out the brake light didn't work either.
Old 02-20-2015, 06:26 PM
Just Strokin Just Strokin is online now
Just Strokin is gaining momentum as a positive member of FTE.
Have you checked you owner's manual for a fuse location that controls this light?
go here and download an owner's manual if you don't have one
https://owner.ford.com/servlet/Conte...e&ord=20630312
__________________
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Camper Package, Cable Lock, Husky Floor Liners, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Old 02-20-2015, 07:10 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has much to be proud ofprojectSHO89 has much to be proud ofprojectSHO89 has much to be proud ofprojectSHO89 has much to be proud ofprojectSHO89 has much to be proud ofprojectSHO89 has much to be proud ofprojectSHO89 has much to be proud ofprojectSHO89 has much to be proud ofprojectSHO89 has much to be proud of
The HMSL and the cargo light are on separate fused circuits with nothing in common except their ground. Start there.
The cargo light is supposed to come on with the running board lights (if equipped).
__________________
2001 F250 SD V10 4x4
HVAC FAQs: http://www.ford-trucks.com/forums/75...xpedition.html
Owner's manuals: http://www.fleet.ford.com/maintenance/owner-manuals/
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.” - Mark Twain
Old 02-20-2015, 07:44 PM
I have checked the fuses and they are good, it doesn't have lighted running boards. does anyone know where the ground is connected to? The truck also will go into program mode for electric locks but won't accept a remote. Ford dealer said he never saw anything do that before. They looked up the build sheet and it came "less remote entry" does this control have anything to do with the lights?
Similar Threads
Dome light not working and third brake, cargo light missing ;) thordehr 1999 - 2003 7.3L Power Stroke Diesel 12 02-08-2015 12:19 AM
Dome/Cargo lights question Trophy_23 Super Duty & Heavy Duty 3 03-21-2014 07:56 PM
dome light and cargo light not working northeaster79 1987 - 1996 F150 & Larger F-Series Trucks 1 11-02-2009 03:51 PM
Dome Light/Cargo light stays on beerbelly918 Electrical Systems/Wiring 1 10-10-2005 08:02 AM
Cargo Lamps on 2000 Ranger Firefreak30 Ranger & B-Series 3 10-05-2003 06:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
