Starter spring
Starter spring
A starter motor I was checking out is missing the light spring around the shaft. This is from a 1952 truck motor. I assume it helps ensure the bendix disengages. so I checked another of the same vintage. Also missing the spring. So then I rounded up an older one (40's) from my parts collection. It has the spring. Is it possible Ford eliminated it? My parts manuals only go to 1948. Any help here?
Most of the older drives I have seen do not have the light spring you speak of. I have only seen it on some of the reproduction units I purchased. I assumed it was an improvement to the original but not a necessity. The spring sits between the front collar and the drive pinion and helps push the drive pinion back on disengagement.
I'm with Ross, I don't remember ever seeing a smaller spring on the later Flat-8 engine.
Are you talking about the one in the first picture below? Mine (second picture) has the grooves that engage the rifling in the drive gear. There is no place for a spring there.
Granted, mine is a '53, but I don't think there is a difference in the starters from '49-'53.
Effie trucker, Interesting. I located a starter today that looks exactly like yours on the right, and it has the spring, and of course there is room for it. In fact I am going to swap the spring to my other starter. If Ford eliminated it at some point, and it appears they did I don't know why. What would keep the starter gear from coasting into the flywheel when going down a grade?
As to a previous poster's comment, the large spring is a shock absorber and has no ability to move the gear either direction.
I think the idea of the little spring is just to make sure the drive pinion doesn't slide back towards the flywheel after it disengages. It doesn't need to be strong for that. The faster motion of the flywheel after the engine starts and you de-energize the starter pushes the pinion back.
The starter in the picture is installed on the engine or I would pull the gear back and take a picture.
I have been working on this stuff for over 50 years when I bought my first car in 1957 when I was 17. A '41 Mercury coupe that I wish I still had of course. Maybe I began to think I knew more than I did. By the way, the current project is a '52 8RT into a '49 8N tractor.
Thanks as well to ALBUQ F1 for his perspective with the level.
chappys4life
03-13-2009 02:12 PM
BFOOTER03
07-02-2008 07:30 AM
