Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
1949 F-1 Seat bolts
Old 02-19-2015, 06:17 PM
walt460 walt460 is offline
walt460 is starting off with a positive reputation.
1949 F-1 Seat bolts
Quick question; what are the size and thread of the 6 bolts that hold the stock bench seat to the floor on a 1948-52 F-1?
Old 02-20-2015, 09:54 AM
Sportster.Mark Sportster.Mark is offline
Old School
Sportster.Mark is starting off with a positive reputation.
To remove the seat from my '50 F6 I had to grind the bolts off, they looked like 1/4-20's.
__________________
1950 F6
1957 XL modified
1982 KZ750CSR modified
1979 Courier w/SC 3.8
1986 F250 4X4 460 company truck
1994 Crown Vic Police Interceptor
Old 02-20-2015, 11:23 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud of
They are either 5/16" or 3/8" UNF x 1-1/4" is my bet. There was a thread about them a year or two ago, the p/n is real hard to nail down. Here's for '53's
Click the image to open in full size.
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree MSD, Rochester 2G, Red's Headers
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Unobtanium Man
Jolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to behold
The parts book I have shows the bolts for the 53/ so I can't answer your question without removing one from my truck.
For the 53/ the size is 3/8" -16 x 3/4". I'm pretty sure my 51 seat bolts are bigger than that.
If no one else comes up with an answer, I'll go take one out to measure it.
__________________
Joe
51 F4 "Betsy" http://www.ford-trucks.com/forums/10...4-project.html "If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
Old 02-20-2015, 11:46 AM
Thanks everyone, I did some testing this morning and found that they are 3/8-24F. My 49 and the 52 are the same.
Mid-Fiftys sells Seat Track stainless steel bolt kits, and they claim the bolts are the same 1948-56. I think I will order a set ($7) to see if they fit.
Meanwhile, I just chased the treads with a tap and then coated a bolt with anti-seize and filled each hole so I can clean the rest of the cab.
Old 02-22-2015, 11:10 PM
Just FYI, the bolts that hold the door hinge to the cab are 5/16-24F. I can find ones at local hardware that fit, but they have an allen-head, not the big Phillips-head like factory. Anyone found a good source for factory-like bolts?
Old 02-22-2015, 11:15 PM
Old School
I get all of my bolts from a company named "Tacoma Screw". I don't know where you are, but any major city would have a nut and bolt company.
__________________
1950 F6
1957 XL modified
Old 02-23-2015, 07:36 AM
cstempert's Avatar
cstempert cstempert is offline
cstempert is starting off with a positive reputation.
Quote:
No one reproduces the exact same 3/8-24 countersunk ovals head Phillips screws
Most make the Allen head and I have seen flat faced countersunk Phillips screws listed as replacements although they are noticeably different if going for a restoration
__________________
1949 Ford F-6 Dump truck - in progress (Soon to be Marmon Herrington 4x4)
1950 Ford F-1 Panel Truck - apart
1997 Ford F-250HD - she plows
1997 Mercury Mountaineer - RETIRED
2001 F-550 Dump Truck - Fer yard werk
2014 Ford Explorer - Work-mobile
Old 02-23-2015, 09:34 AM
ALBUQ F-1's Avatar
postin' fool
I believe Roy Nacewicz has the correct door hinge screws, as they were used for other things on older Ford cars. They won't be cheap!
Roy Nacewicz Enterprises Ltd - Ford Bolts
__________________
Ross
Old 02-23-2015, 12:16 PM
drptop70ss's Avatar
drptop70ss drptop70ss is offline
drptop70ss has a good reputation on FTE.drptop70ss has a good reputation on FTE.
Comparing them to my 55 chevy I dont think the Ford ones are that much different. As usual the chevy stuff is everywhere so price is low.
https://www.yearone.com/Product/1955-57-chevy/dm258
Old 02-23-2015, 05:19 PM
fordf348's Avatar
fordf348 fordf348 is offline
fordf348 is starting off with a positive reputation.
Am I missing some bolts? My 48 F-3 has 4 bolts holding the seat to the floor.
Ed
near Philadelphia
Old 02-23-2015, 05:49 PM
Unobtanium Man
Quote:
Ed
near Philadelphia
My 51 has 5 bolts, 3 on the drivers side and two on the passenger side.
__________________
Joe
Old 02-23-2015, 06:34 PM
ALBUQ F-1's Avatar
postin' fool
There is a side-to-side brace on both sides. I don't recall if that uses the same size bolt or a smaller one?
__________________
Ross
Old 02-23-2015, 07:30 PM
Unobtanium Man
It's the same size bolt. My truck's floor has the holes for the brace on both sides, but only has the brace on the drivers side.
I thought maybe the extra hole was for the right hand drive cabs sent to other countries.
__________________
Joe
Old 02-23-2015, 09:18 PM
Thanks for the info on the door screws, I am going to check out both sources and see what I find, will post results later.
Similar Threads
Installing intergrated seat belts on F150 seat jasoncb1 2004 - 2008 F150 2 02-01-2012 07:34 AM
Would a 1970 F3 bench seat bolt directly to my 75 F2 FordmanShane 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-08-2012 08:22 PM
Need seat help...swap from cloth to leather Paul H. 1999 - 2003 7.3L Power Stroke Diesel 3 06-05-2005 09:00 PM
Bronco Seats for my F250? RennGear 1987 - 1996 F150 & Larger F-Series Trucks 2 02-13-2004 01:48 AM
Bucket seats for a 78? mud bug1 1973 - 1979 F-100 & Larger F-Series Trucks 3 06-26-2003 09:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
