motor plug-in sheathing
Noticed today, while ripping IC out to clean and install my R.R. boots, that the sheathing around the motor plug-in wire was completely gone/cracked/ coming apart. So, with room to work, i wire-loomed it all up. Just a head-ups to those that plug-in at night, to take a gander at it..
No way would I trust it. How can you know what it looks like inside the molded plug? That is where the unseen damage occurs that leads to the fires. The poorly designed flat cord bends back and forth over the years gradually breaking the strands of wire inside where it joins the molded end until the connection is so reduced that enough heat is generated to start a fire. A bare cord will only short out and trip a breaker.
Get a new cord or do the Marinco mod, your old cord is just a ticking time bomb.
appreciate the concerns, guys. I feel i have nothing to worry about because the wires themselves, looked good. It was the sheathing that was heat impacted and brittle/breaking apart. Also, being in So-Cal, i have yet to use it (5yrs) and think i should be ok, with not using it. It was a mere distraction, that i saw the damage, which i felt i should share with members that do plug-in at night...
learpilot
10-25-2009 06:09 PM
nflfreak43
23
05-12-2009 12:20 PM
mward69
06-07-2007 05:38 PM
