no start no WTS - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
no start no WTS
Old 02-19-2015, 04:37 PM
pilgrimbizket's Avatar
pilgrimbizket pilgrimbizket is offline
pilgrimbizket is gaining momentum as a positive member of FTE.
no start no WTS
So truck wouldn't start on Tuesday. In michigan till march but need the truck on arrival.
Put key in ignition as I turned the key the WTS light came on for a sec then all power to the truck was lost.
I took battery cables off and cleaned them. No luck.
Replaced fuse #22, still not recieving a WTS.
https://docs.google.com/file/d/0Byb4NbQJIHUPY2x4WU1qRU1VVGc/edit?pli=1
^ I found that while on vacation.
I made it down to fuse #22 is good, now to check the pcm for power.
How do I go about checking that red wire?
Old 02-19-2015, 06:01 PM
madpogue madpogue is online now
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Did you disconnect the fuel filter heater before replacing fuse #22?
Old 02-19-2015, 07:01 PM
I have e fuel so its all un plugged
Old 02-19-2015, 07:04 PM
Are you sure that connector isn't touching something that's shorting to ground?
Old 02-19-2015, 07:10 PM
Quote:
Thank you for the responses.
Its something to check but I put heat shrink over them when I cut the wires
Old 02-19-2015, 07:25 PM
Are you by any chance using that circuit for the e-fuel pump? If so, I would disconnect it, and see if at least that turns on the WTS light. Other thing I would try is disconnecting the red/green wire from the GP relay, since that's also on the PCM power circuit. Again, just to see if that gets the WTS light on.
Old 02-19-2015, 07:32 PM
E fuel is taking power from starter relay.
I will try the gp relay. I put a oem gpr in back in October. But I will check it out as well.
Old 02-20-2015, 07:53 PM
Bump.......
Old 02-22-2015, 09:24 PM
Any other ideas?
Old 02-23-2015, 09:52 AM
sean9049's Avatar
sean9049 sean9049 is offline
sean9049 is starting off with a positive reputation.
the truck is in p right not in reverse but looks like park, just an idea
Old 02-23-2015, 10:07 AM
Quote:
Its in park. Thank you though
Old 02-23-2015, 12:24 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
Does your truck still crank over when when the dash goes dead. What about by jumping the starter relay. It sounds like a bad connection to me
Old 02-23-2015, 12:41 PM
Quote:
Negative, the truck does not crank.
It seems like a bad connection somewhere.
I had a similar issue in December. I replaced the starter relay with a parts store version. The problem was corrected till this past week. Now the same issues have risen. So I went to ford and purchased a OEM version. Anyways the OEM relay did not change anything.
No cranking, no WTS
Grounds are clean, battery terminals are clean, fuse 22# is good.
Can a burned 3rd brake light cause these symptoms?
(I would of checked before I left but my camper shell is in the way.)
Old 02-23-2015, 12:48 PM
Quote:
Originally Posted by pilgrimbizket View Post
No cranking, no WTS
That changes the game completely. Cranking and running the engine are on two completely separate circuits, and the only thing in common between them is the ignition switch (and, of course, main battery connection). Your problem is either way "upstream" with a maxifuse that energizes the ignition switch, or the switch itself, or as said above, a major battery/ground connection.
No, completely unrelated.
Do ANY accessories work? Headlights, brake lights, parking lights, hazard flashers? What about key-on accessories such as the HVAC blower and turn signals?
Old 02-23-2015, 03:54 PM
After the truck has sat randomly some times when I open the door the dome light will come on, and then it shuts off quick. So the truck has power randomly but gets interrupted and just turns off with in a a second. The first time this happened last Sunday, the keys where in the ignition WTS came on for a second then all power was lost. The truck will act completely dead
Negative at times the dome light will work when the door is opened. but power is quickly lost before I can even try activating any accessories
Gretchen and her Electrical Fit. Awitte58 1994.5 - 1997 7.3L Power Stroke Diesel 28 01-01-2016 10:57 PM
Help please no start Tspangler 1999 to 2016 Super Duty 1 12-27-2015 07:16 PM
Fuse #22 short UPDATE GreaseMonkey519 1994.5 - 1997 7.3L Power Stroke Diesel 6 12-12-2015 09:11 PM
97 power stroke no start , no wts light Madisontree 1987 - 1996 F150 & Larger F-Series Trucks 0 12-05-2015 09:49 PM
HELP PLEASE No start, no WTS light bunklash 1999 - 2003 7.3L Power Stroke Diesel 6 05-16-2015 08:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
