5spd manual tran.
Old 02-18-2015, 10:11 PM
my 66's Avatar
my 66
my 66 is offline
5spd manual tran.
I have a 5spd out of a 98 f-150, it has the internal hyd. throw out bearing. I would like to change it to a external slave cyl. type throw out bearing. Has anyone done this? would like to heir how it came out.
Old 02-22-2015, 06:36 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
You might have better luck in the transmission forum.
Old 02-22-2015, 08:51 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,578 Likes on 1,288 Posts
Having stalked the trans forum since the day I joined, I can tell you with some certainty this has not come up. If you can weld aluminum and are good at fabrication and don't mind having a "one of a kind", you can probably make one work.
Easier to put a juice set up in imo........ but I ain't doin' the work now am I...
The 460 and oil burner ZF's have the cylinder outside the bell with a regular type fork, but I'm pretty sure you are working on a Mazda box there.
Old 02-26-2015, 04:41 AM
Frdtrkrul's Avatar
Frdtrkrul
Frdtrkrul is offline
Might just be better off either getting a different transmission or staying with the Mazda M5R2. A small block ZF5 with the modular engine bell housing might be a good choice, can't recall if that one is internal or external.
jurgak
06-29-2007 11:16 PM
todd88
15
01-22-2006 10:03 AM
intimidator
09-05-2005 11:16 AM
blatherskite
11-19-2003 04:44 PM
Quick Reply: 5spd manual tran.
