Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Large Truck
Sign in using an external account
Register Forgot Password?
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Power steering brackets for Y block
Old 02-18-2015, 06:41 PM
fakesnake fakesnake is offline
fakesnake is starting off with a positive reputation.
I bought the power steering set up from a 72 C600 with what i think was a 400 engine? I have the big Y block truck engine on my 58 C800.
The power steering reservoir is an Eaton type with coils wrapped around outside. I need a bracket that will fit my engine as the one that came with it it won't work. I was thinking brackets off a late 50's model T bird with Y block would work.
Any thoughts or experience on this?
__________________
1958 Ford C800 (former fire truck)
1962 Mercury Monterey Convertible
Old 02-19-2015, 01:24 AM
big job's Avatar
big job big job is offline
big job is gaining momentum as a positive member of FTE.big job is gaining momentum as a positive member of FTE.
Lets see you have a 1958 C800. If it is original forget the 1950's TBird
that should be a Y block 312 and later Birds gave way to FE blocks. You
have or ( should have ) is a Y block Lincoln 302 or 332 which is a rugged
cast mount. I would get into Hemmings lots of venders specializing in
Lincolns and Check 1957 Mercury with 368 Y block (same block). Last
resort is to make one. Its really no big deal to fab a mount. Hope this
helps.
sam
(I known cause I have two trucks with Y-332's with power steering)
Old 02-20-2015, 10:27 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
292/312 1955/57 Thunderbird; 352 standard equipment in 1958/60 Thunderbirds; 430 optional in 1959/60 Thunderbirds.
These use the Eaton P/S pump, its reservoir bolts to the top of it (see pic at right).
1958/65 Lincoln 430 & 1966/67 Lincoln 462 used the Vickers Drive P/S pump, which ran off the crankshaft.
Pic at left: The P/S pump mounting brackets (3C511 & 3A732) will have to come from a 1957/63 truck with a 302 or 332 Lincoln derived Y block, nothing else will work.
btw: No such thing as a 400 engine in a C Series truck.
__________________
Bill / Retired Ford Parts Manager / SoCal Chapter Member / Part number research: 1928/2001 trucks & 1928/89 passenger cars.
2013 Escape FWD 2.0L Eco-Boost
Similar Threads
Power steering Pump bracket issue ecard 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 04-12-2015 04:42 PM
power steering pump & pulleys abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 2 03-28-2015 09:45 PM
power steering pump bracket abyars111 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 03-23-2015 10:23 AM
1960 Ford F100 Power Brakes And Power Steering Question fireball14513 1957 - 1960 F100 & Larger F-Series Trucks 38 12-27-2014 08:25 PM
56 Ford F-100 Steering Column Parts Outlaw56 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 07-22-2013 09:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
