Troubleshooting glow plugs
Old 02-18-2015, 06:35 PM
dev_jhnsn's Avatar
dev_jhnsn
dev_jhnsn is offline
Having an annoying cold start issue. 97 7.3. The truck will not start without a fight if temps are under 50* outside. If i plug in, shes fine. Checked glow plug relay, all is good there. Check resistance on all my glow plugs. All read at 1.5 ohms, but cyl #2 is up around 5.7 ohms. How does one have that much resistance? Also, terminal in the pig tail for cyl #3 is burnt out. I have 12v power to every glow plug, however. Could the one glow plug with high resistance, and the one with burnt out terminal cause this hard start? Any info appreciated
Old 02-18-2015, 06:37 PM
dev_jhnsn's Avatar
dev_jhnsn
Also, new engine and glow plugs 2500 miles ago. Its my first diesel so im still getting used to the thing.
Old 02-18-2015, 06:39 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I can't see 2 bad glow plugs make it start hard in 50* weather
but if you have one burned out one in 2500 miles you have a problem.
What brand are they? If ANYTHING other than Beru or Motorcraft, pull them NOW
Old 02-18-2015, 06:49 PM
dev_jhnsn's Avatar
dev_jhnsn
They are zd-11 right from the dealer. What could cause one to burn out so quickly? Im pulling my hair out on this.
Old 02-18-2015, 07:00 PM
lemonshindig's Avatar
lemonshindig
lemonshindig is offline
1.5 should work, but based on my personal observations, it's not quite ideal.
All 8 of my new ZD-11s were 0.8 ohms dead on. So were all 8 of the Berus that I pulled out.
Are you sure the relay is good? 12V to the glow plug side when someone first turns the key? And for how long does it stay at 12V? Maybe the controller is bad.
Old 02-18-2015, 07:07 PM
dev_jhnsn's Avatar
dev_jhnsn
Yes i only lose maybe .5v across the relay. And if i check voltage at the plug for the glow plug, i have a 12v reading. Glow plugs stay on for roughly a minute. Give or take.
Old 02-18-2015, 07:23 PM
Diesel_Brad
You have me stumped
Old 02-18-2015, 07:26 PM
madpogue's Avatar
madpogue
madpogue is offline
May be your problem. Loss across the large terminals should be no more than 0.3v.
Old 02-18-2015, 07:40 PM
dev_jhnsn's Avatar
dev_jhnsn
You have me stumped
The feeling is mutual haha
Old 02-18-2015, 07:41 PM
dev_jhnsn's Avatar
dev_jhnsn
The relay is a cheap one. About a year old.
Old 02-18-2015, 07:53 PM
madpogue's Avatar
madpogue
madpogue is offline
^^^^ Easy confirmation - use a jumper cable, jump across the two big terminals (or go direct from the battery + to the big terminal that connects to the GPs). 20 seconds or so, then see if that helps it start.
Old 02-18-2015, 07:56 PM
dev_jhnsn's Avatar
dev_jhnsn
I will give that a try in the morning when the engine is cold.
Old 02-18-2015, 09:48 PM
lemonshindig
I have been doing as modpogue suggests to start my truck the last two days (awaiting my new relay), but after 5 seconds of jumping to the glow plug post, the truck fires right up.
Old 02-18-2015, 09:49 PM
lemonshindig
Check your - battery to engine cables for corrosion and tightness.
Old 02-18-2015, 11:26 PM
dev_jhnsn's Avatar
dev_jhnsn
Connections seem okay all around. I will see about jumping the relay in the AM
Quick Reply: Troubleshooting glow plugs
