Troubleshooting glow plugs
Old 02-19-2015, 04:29 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
FYI. A very good "jumper cable" is a screwdriver across the posts. Hold it there for at least 30 seconds
Old 02-19-2015, 04:33 AM
stuart1's Avatar
stuart1
stuart1 is offline
Originally Posted by dev_jhnsn
Connections seem okay all around. I will see about jumping the relay in the AM
Seem ok does not work. Remove the connections and scrape down to bare metal.
Old 02-19-2015, 04:45 PM
dev_jhnsn's Avatar
dev_jhnsn
dev_jhnsn is offline
Let me rephrase. Connections are good.
Old 02-19-2015, 04:48 PM
dev_jhnsn's Avatar
dev_jhnsn
Just tried this. The truck did fire after a couple seconds of cranking. Something to note; the relay was buzzing, but as soon as i set the screwdriver across the posts, it stopped.
Old 02-20-2015, 12:42 AM
farmert's Avatar
farmert
farmert is online now
The buzzing you heard was the electricity jumping between the rely contacts. Your relay is shot.
Old 02-20-2015, 07:23 AM
dev_jhnsn's Avatar
dev_jhnsn
Thanks for the reply. I have a new relay, valve cover gaskets, UVCH and a pigtail that should be arriving in the AM. Hopefully this hog will be up and running as it should.
scottm1
19
02-01-2020 05:55 AM
kent hittle
11-21-2015 06:56 AM
RougeDoc
03-11-2009 12:16 AM
Ed the outdoorman
07-09-2003 10:17 PM
kellerkathleen
03-01-2003 12:55 PM
Quick Reply: Troubleshooting glow plugs
