Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
1966 frod f100 front alignment
Old 02-18-2015, 09:23 AM
1961mike 1961mike is offline
1961mike is starting off with a positive reputation.
Does anyone have info on a company or individual that will adjust camber on a twin-ibeam suspension in the state of Georgia ?
Old 02-19-2015, 07:32 PM
topscrt's Avatar
topscrt topscrt is offline
topscrt is starting off with a positive reputation.
wickedV10
go to places that do semi truck aligment. you have to bend the twin I beam to straighten it .
Old 02-19-2015, 07:45 PM
PapaMatt PapaMatt is offline
PapaMatt is starting off with a positive reputation.
What topscrt said. I took mine to three shops and a finally one shop called around and found someone about 1.5 hours away from me that can do it. I have to fix my column first before I can get it done. If you can find a classic car/truck shop they will likely know someone that can do it.
Old 02-25-2015, 10:48 AM
alignment on twin ibeam
Papamatt do you have address and name of person or company so I can get my alignment, in Hillsborough, n.c. Thanks 1961mike
Old 02-25-2015, 11:28 AM
1961mike - They are not located in Hillsborough, unfortunately (for me anyway). They are in Kernersville. The name of the place is Beck's and here is a link from Google with all of the pertinent info.
https://plus.google.com/105263485716...ut?gl=us&hl=en
Good luck!
Old 02-25-2015, 11:51 AM
bphirt1 bphirt1 is offline
bphirt1 is starting off with a positive reputation.
Quote:
Hello. I live in Acworth and just got my 66 f100 last week. Let me know if you find a place. I will let you know if I find one. I am going to call some classic car places near by.
Old 02-26-2015, 06:40 AM
Alignment
thanks guys for all the help.I will let you know if I find an alignment shop
Old 02-26-2015, 09:55 AM
Hi Mike. I found a shop in Roswell GA that does the alignment for $100. Perfect Performance. 770-993-4222.
Old 02-26-2015, 11:53 AM
Pickupmanx2's Avatar
Pickupmanx2 Pickupmanx2 is offline
Pickupmanx2 is a name known to allPickupmanx2 is a name known to allPickupmanx2 is a name known to allPickupmanx2 is a name known to allPickupmanx2 is a name known to allPickupmanx2 is a name known to all
I am just going to say,,, In all the years I have had my old Fords, and I have had A LOT of them, I have never, not once ever had to have the camber adjusted,,, now, if you have bent them for lowering purposes, ok,, but from normal everyday thrashing on mine, especially as a young stupid Jarhead, launching it over tank traps, never have I bent one,,,
Did you add a coil lift, or what is your reason for needing camber adjusted?
__________________
SEMPER FI
02/Ex/4x/7.3/Limited
02/F350/CC/4x/7.3/Lariat/DRW
77/F150/SB/4x/NP435
66/F100/240/T18
63/F250/Flatbed/4x4/T-18
Old Yesterday, 08:08 AM
Ibeam adjustment
If you look at the front of my truck there is too much positive camber on the driver side it is going to wear the tires out need to adjust that in the shop manual from Ford it shows you must bend the I-beams in order to fix the positive camber
Old Yesterday, 02:33 PM
Haven't seen the front of your truck,,, did you replace springs?
Have you tried switching springs from side to side? Not trying to knock you or disagree,,, I know the only way to adjust camber is by bending beams, I am just saying, that in all of the Ford 2wd trucks I have owned, I have NEVER had to have the camber adjusted, i.e. bend the I-beams. My 66 F250 I had, I put different coils on it, and it had a slight positive camber. Just personally, I would look at other options before you have them bent.
__________________
SEMPER FI
77/F150/SB/4x/NP435
66/F100/240/T18
Similar Threads
Vote for the Georgia Sticker ChiefM Georgia Chapter 9 03-24-2014 11:32 AM
Free to a good GEORGIA home: maroon 80-86 dash pad Dorsai Georgia Chapter 0 11-02-2012 03:28 PM
Southeast Georgia members ManfredVonRichtofen Georgia Chapter 40 04-18-2012 06:21 PM
Anthing in Georgia??!?!?!?!!??!! Evan99 Competition 5 07-10-2010 11:24 PM
Who's from Georgia? 77_F150_4x4 General NON-Automotive Conversation 4 02-28-2001 01:24 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
