Stalled in Allentown PA
Old 02-18-2015, 07:25 AM
ithaca1230's Avatar
ithaca1230
ithaca1230 is online now
Last night pulled in at rest stop in Allentown and truck started surging then stalled put dieselkleen in and topped off tank but no luck eventually would not run at all. Had it towed to ford in Allentown and this morning started right up running fine. Having them change fuel filters. Not sure what to do got to get back to ithaca my about 3 he drive any thoughts? Thanks
Old 02-18-2015, 07:28 AM
Iaff113's Avatar
Iaff113
Iaff113 is offline
Check the ficm
Old 02-18-2015, 07:47 AM
ithaca1230's Avatar
ithaca1230
Just had Ed at ficmrepair go thru it and put eono tune in it about two weeks ago
Old 02-18-2015, 07:51 AM
Iaff113's Avatar
Iaff113
Iaff113 is offline
Do you have gauges on it?
Old 02-18-2015, 08:13 AM
ithaca1230's Avatar
ithaca1230
Yes all ok fuel pressure ok no codes checked them with sct
Old 02-18-2015, 09:02 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
So if I understand correctly the truck is running ok and your concerned about re-jelling on your 3hr drive home?
Old 02-18-2015, 01:53 PM
ithaca1230's Avatar
ithaca1230
So I had them change the fuel filters and clean MAP sensor ( cleared the tube ). Truck ran perfect rest of the way home. Never had that problem before. I'm guessing the fuel gelled? Technician said the filters looked ok. The heat would not work when it started this morning. He pulled the fuse and put it back in and the module reset and works fine again. Should I be looking for anything else? I'm back in Ithaca
Old 02-18-2015, 07:45 PM
Per4mance's Avatar
Per4mance
Per4mance is offline
My truck jelled while running down the road in Pa this weekend,I never heard of that happening but it just goes to show ya -11 is cold and can make weird things happen. The diesel tech at the service station said it has to do with the altitude and the cold.Told me they triple up on anti jell up there
Old 02-19-2015, 09:00 AM
ithaca1230's Avatar
ithaca1230
Never had that happen before. Wish I had the right allen wrench to bleed filter if that would have made a difference. I had a folding set but wouldn't work cause drive shaft is too close.
Old 02-19-2015, 08:36 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Altitude can effect the boiling point but never have I heard of the freezing point.
I would more inclined to just say it's too damm cold.
I think he just made that up.
Here is why. They are talking about water and liquids
Freezing point depression and boiling point elevation: the effects of solutes and of pressure
Now some indirectly related stuff.
Five myths about diesel engines | Argonne National Laboratory
Now if you really want to look at some tables and make your brain
have some problems look here.
Engineering ToolBox
Sean
Old 02-20-2015, 07:01 AM
Per4mance's Avatar
Per4mance
I had more than enought additive for the fuel and it jelled, added a half gallon of Howes and it ran and got me home......don't ya love it when a plan comes together?
Old 02-20-2015, 08:38 AM
ithaca1230's Avatar
ithaca1230
I had driven thru a street that was flooded from a water main break and had a lot of ice accumulated under the truck. I had not noticed this at the time. I always add dieselkleen but had not in a couple tanks. after stalling I dumped double the amount but it wasnt till morning before it would start again. It has been ridiculously cold here in the finger-lakes region of NY for the past 4 weeks now. They showed me the ice at the shop and after changing the fuel filters I went to a car wash and got the rest of the ice off. Just never had this happen before and wondering if there is something I could have done to prevent this or if maybe somthing else is going on. Thanks for all the responses.
badaz4570
07-15-2015 06:26 AM
bigcountry1009
1999 to 2016 Super Duty
11-12-2014 11:09 AM
ldwzlaw
38
07-16-2012 08:48 PM
Vinford
05-01-2008 10:41 PM
Quick Reply: Stalled in Allentown PA
