how hard to pull the bed?
Just curious how hard it is while waiting for warmer weather. Thinking it might be easier to pull the bed to service the fuel tanks and replace fuel and brake lines than to do it all from underneath. Could scrape surface rust and epoxy paint the frame while it's off.
So how hard is it to pull the bed? How many people does it take to lift off when everything is freed?
I've done it with one other person but it's a strain and you need sawhorses or drums to sit it on.
I've also done it most recently by myself because nobody was available to help. Took a bit to rig it but now I could do it alone in no time.
Excuse the mess!
The crossbar and the big chain fall came out of my Grandfathers garage and was used on A-Models etc. Before opening his own garage he worked in the Ford Assembly Plant in Charlotte. My Ford blood runs deep!
Excuse the mess!
Received 3,101 Likes
on
on
Round you up some bolts and frame U-Nuts from the 97-up body style and use them when reinstalling. They work great and make the next job a cinch....from above! Mine may have come off of a non-Ford, IDK. Don't look exactly like the Ford items. I found them in a pile in the cab of a truck at the salvage yard and had the 'light bulb moment" and snatched them up.
on
I looked at some pics on eBay, looks easy enough. Those clips/nuts will line up right on our older frames? That would make it quicker.
