2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
09 Expedition cold start - stalls when put in gear
Old 02-17-2015, 01:25 PM
Mr. Crab's Avatar
Mr. Crab
Mr. Crab is offline
And only on a cold start, first thing in the morning. After the truck has warmed up it has no further trouble. If I let it run for about a minute after starting, it's also fine. It's probably just a coincidence, but this started right after I changed out my original battery. Anybody else have a similar issue and learn how to fix it? I don't get a CEL by the way.
Old 03-13-2015, 09:56 AM
Mr. Crab's Avatar
Mr. Crab
Mr. Crab is offline
Well, I found the problem, and boy, do I feel like a dope. When I changed the battery, I was a "little" overzealous with the red spray terminal protector gunk. In fact, I sprayed the terminals BEFORE I reattached the battery cables, thinking that if I twisted them as I worked them into place, it would displace the red gunk wherever I was making tight contact, leaving a good film on the parts of the terminal where I wasn't. That don't work quite the way I envisioned. Just for grins, I pulled the cables off, and discovered I still had absolutely great coverage on both terminals. All of both terminals, LOL! A little while later after some rather delicate sandpaper treatment, I reattached again, and this time I only sprayed after tightening to spec. Worlds of difference. I'm probably pretty darned lucky nothing burned out.
Grumpy Moose
1999 to 2016 Super Duty
03-27-2020 08:49 PM
canadajin
Modular V10 (6.8l)
16
12-09-2010 07:07 AM
solarwater
1997-2006 Expedition & Navigator
02-27-2009 07:50 PM
jojo418
1997 - 2003 F150
02-04-2004 05:09 PM
kati
1997 - 2003 F150
01-07-2004 02:34 PM
Quick Reply: 09 Expedition cold start - stalls when put in gear
