Wastegate or EBPV?
Old 02-17-2015, 08:24 AM
rbmcveigh's Avatar
rbmcveigh
rbmcveigh is offline
Trailering
Wastegate or EBPV?
99 F350 7.3L SRW. We have been having some incredibly cold days lately (-20 right now), and I've noticed when taking off, I can hear a "hissing" noise under acceleration. I say hissing because I can't tell if its a vacuum or a pressure leak. Once I let off the accelerator, it goes away and may or may not come back when I hit the accelerator again.
I am trying to figure out if it could be the wastegate relieving or the EBPV sticking. I did stumble across a code on my reading that said the backpressure was abnormal (P0470), but it wasn't enough to set a check engine light.
Anyway to check to see what is going on without dismantling everything?
Old 02-17-2015, 09:31 AM
Tugly's Avatar
Tugly
Tugly is offline
EBPV all the way. This helps the truck to warm up faster. You'd really see a show with an EBP PID on a scan tool/gauge.
Old 02-17-2015, 11:43 AM
jhl3's Avatar
jhl3
jhl3 is offline
If it is below 37 degrees F and your engine oil temp is below 140 it is more than likely the EBPV. When one of those temps rise above the threshold temp you should no longer hear it.
Old 02-20-2015, 01:50 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
Justin@DP-Tuner is offline
PREMIUM SPONSOR
As stated, EBPV definitely. You will never hear a wastegate on a 7.3L.
Does the truck feel somewhat under-powered when it is hissing as well?
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
rbmcveigh
1999 to 2016 Super Duty
02-17-2015 09:04 AM
02-7.3l-toy
02-13-2010 12:54 AM
johnsps250
02-08-2007 10:45 AM
ArcticMotorsports
10-27-2006 03:37 AM
jmbatlanta
01-07-2004 12:31 PM
Quick Reply: Wastegate or EBPV?
