Volare/LeBaron front
Performance Suspension Technology (PST | Car & Truck Suspension Parts | Performance Suspension) carries complete rebuild kits for the various Volare IFS's. As for the rationale behind installing a Volare IFS in 2015, let's just say it's not the first choice for an IFS today. While most parts are available, a few are tough to come by...namely the torsion bars with new bushings. As for the IFS itself the lower control arms are weak, the brakes are small by today's standards, and the travel of the suspension is short. 40 years ago this was a hot setup but today not so much.
mustang 2 based would be my first choice
to keep a budget low and easy I would go crown vic
jag would be my 3rd choice as its old enough it would need a rebuild.
This is from a guy with a volare front suspension, its in and it works its nice that its adjustable. but the other installs are cleaner and easier. Plus the volare uses a steering box, I would much rather have the rack and pinion.
on
GDub
I'll add one more point to consider... from personal experience... depending on your engine choice... things can get crowded in the engine room. I had a Volare at first with a 460 block... I had offset to the right 2" for clearance around the steering box. When it came time for headers I had more interference problems... and on both sides...
I opted to remove the Volare and go with Mustang II... a major change that involved a lot of work... done now and I"m happy
My point is... just make sure you will have adequate room for everything that has to fit in the engine compartment... but sometimes youj can't tell till you hit the wall... hope it helps
john
john
My 1956 F100 has a Volare front IFS, was installed before I bought it in 1986. I have had it checked by a frame shop, and it was done right including the welds. (It is saddled onto the original frame) I am ready for another rebuild now, but it has been great for a lot of miles. Bigger brakes are now available as are all the service parts, but it is a 1970's IFS design.
I like the 2003-up Crown Vic set up, but it has too wide a track for these trucks if you want to keep the classic look with your wheels. It does make it easy to install a Mod Motor including the new 5.0L Coyote (with an aftermarket power steering pump mount). I am aware that Edward Ritchey is making a 4-3/4" narrowed version and hoping to see one installed on a 1953-1956 frame soon. (Not sure what this does for Mod Motor mounting.)
I put a Volare under my 53 F100 because there was lots of tech articles at the time regarding the install and I had access to a low mileage unit complete for $75. It has served me well but I would not use it again. As already has been stated, too many better options today. If I could not afford the current ones then I would stick with parallel leafs and beam axles until I could.
I was going to use a crown vic as I did have one sitting in my garage as I also have the le baron/volare. My first truck I had a mustang2 put in but sold the whole thing before I finished it.The truck I have now has the i-beam plus disc brakes but just don't want stock even with all the power steering that you can get for them. I more than likely will do the tci as it has new upper a-arms. I looked at no limit but have not decided yet. As far as me doing all the work Hell no. I do know my limits and I don't want junk to run up and down the road. I have friend to do the work he has a shop and does turn key cars and bikes and has been doing it for years here in the springfield area. Thanks for all the response I do like this site and am also on another site that is helpful.
I sent ya an e-mail.
bret
Art
It really doesn't matter if you use the crown vic, the jag or the chy front end. They are all good and will make your truck drive better. The chy is good and is under hundreds of trucks as well as millions of the chy. cars. It will be like all the rest, in 15 or 20 years everyone will be telling you how ancient and stupid it would be to put a crown vic or jag front end under your truck. Parts are available for them. Mine has a chy front end and drives great. When it was installed many years ago it was a very modern front end. Are there better choices today? Perhaps so. Will the better choices be outdated someday? Of course. So put in what you want to and feel comfortable with. Things advance and the new will become old and outdated and in the future someone on some forum will tell you how dumb it was to install a internal combustion engine in your truck when so many better choices are out there.
Larry
Larry
