FICM Trouble or something else?
2004 6.0 Diesel. First the truck would die after starting, then start up again after a minute.
Then the truck wouldn't start at all.
Trouble codes indicated low voltage on all injectors leading me to conclude a dead FICM. Replaced the power module in the FICM and reinstalled, but still no start.
48V at driver's side screw under the cover. 12V at the next screw, the next appears to be ground. The passenger side screw is 0V. One post indicated that should also be 48V - is the true?
I probed the power coming in - logic fuse is good. 50A fuse in the cab is good. Relay seems good.
The Ford FICM diagnostic indicates 12V power should be coming in on FICM connector X3 on pins 7, 8, 4, 23, 24, 25. I have 12V only on pins 7, 9, and 27. When I pull the relay I lose power on pin 27.
Advice?
Advice?
Not sure, maybe check the connections at the back of the ficm. Make sure they are all snug. It is easy to break the tabs off so they don't lock in place.
Or possibly what Grant was getting at the ficm has 2 parts: the logic board and the power board. More often the power board fails and it is an easy fix/replacement. It is possible the logic board failed instead.
If you really want to get some good ficm info give Ed a call at ficmrepair.com. He is the ficm guru for lack of a better name. He really knows his stuff, will talk your ear off, and I'm sure he'd be more than happy to help you figure it out.
^^^---Bingo! It hard to talk details online without info. We can guess and help you spend money on parts but I'm sure you'd like to just buy the one that fixes it.
Here's a thread to help give you an idea of what's available, what they can do, and what they cost. Some are suprisingly inexpensive and can be a big help zeroing in on the problem.
Click here---> https://www.ford-trucks.com/forums/1...eral-info.html
Update IPR 85% and ICP 150 PSI
Scangauge arrived yesterday, programmed it and ran the checks.
FMP 48.5V KOEO and while cranking = Ok
FLP 12.0V KOEO and while cranking = Ok
SYC 1 while cranking = OK
IPR 14% KOEO and 85% while cranking = bad
ICP O KOEO and while cranking gets up to about 150 PSI = bad.
While cranking the crankcase oil pressure comes up to normal.
Time to start wrenching to find source.
Sounds like you're on it. Of course leaks anywhere in the system can cause low pressure, the IPR valve may be bindidng or defective. The early trucks have a pretty solid High Pressure Oil system, unfortunately the weakest link (just going by the odds) was the pump it's self. Late '04 and up trucks got a better pump but new plumbing issues.
Anyway, if you have the metric fitting required to put shop air in the icp hole and use a jumper wire to close the icp, a bad pump can be verified by air leaking into the oil filter housing. Or out of the weep hole on the pump it's self. Check the Tech folder for more details on the air test procedure. Often the pump will clearly be binding if you remove it and turn the gear by hand. Rebuilt pumps can be as iffy (and expensive) as the origonal, even from Ford. If the budget allows, you might consider an aftermarket "high performance" unit.
