Reverse sensors not turning off
Hey all,
It's abnormally cold here in the Northern Va area single digits with windchills in the negatives. I ran through the car wash, one of those that hand dries it afterwards to get the salt off my truck. After running the roads I went to back in to a spot and the sensors are going off. Nothing is blocking them so I'm thinking water got inside and froze?
I could not see the crack. The Dealer's body shop said they detected a crack and needed to replace the sensor. I don't know how they tested it. This was a common problem for several years. In the early 2000's Ford had several TSB's for this same issue on just about every vehicle that had the sensors.
Worst case, this is an easy DIY project, you can buy a set of sensors on eBay for around $50 and change them in 30 minutes yourself. Of course it is better if the dealer does it.
Crystal
