1978 - 1996 Big Bronco
help with '86 bronco heater
Old 02-15-2015, 09:19 PM
Tyaz92's Avatar
Tyaz92
Tyaz92 is offline
I just bought an '86 Bronco 351w and the guy told me only the defrost works on the heater, it won't push through the vents, idk where to start to see what's wrong? Any help is appreciated!
Old 02-15-2015, 11:21 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
They still cable controlled in 86?
Old 02-15-2015, 11:34 PM
Torky2's Avatar
Torky2
Torky2 is offline
Sounds like a climate-control vacuum leak. Take a look at the "FAQs" at the top of the Bronco Forum here, there may be something about it. It's a common topic.
Old 02-16-2015, 10:21 AM
1985 Bronco's Avatar
1985 Bronco
1985 Bronco is offline
There is 2 types of heat/AC for 80-86 trucks. Factory installed, which is vacuum controlled, and dealer installed, which is cable controlled. For 80-86 trucks, the heat only comes out the defroster vents, and the floor, if you have vents on the dash, they are for AC only. Does your floor heat work? Is your blower motor working? You may want to remove it, and check if there is anything in there blocking it. It is common for leaves to get in there.
xxkenny90xx
01-28-2016 03:07 PM
cornbinder
06-18-2010 12:17 PM
Craigwell
01-05-2010 04:10 PM
Boxer347
09-07-2006 12:06 PM
Kwattro
02-17-2006 09:04 AM
Quick Reply: help with '86 bronco heater
