No Heat need help!
Old 02-15-2015, 06:55 PM
Beachboss's Avatar
Beachboss
Beachboss is offline
No Heat need help!
1998 f150 5.4 owned since new. 203,000. No heat at all. I've looked in the forums and have checked my switch, actuator, and blend door. All work just fine. Truck heats up normally and never overheats. The truck is full of coolent. Any ideas?
Old 02-15-2015, 07:05 PM
shooter123's Avatar
shooter123
shooter123 is offline
if you actually saw the blend door move I would flush the heater core. then point the truck nose uphill or just use a jack. then remove coolant cap and run with the heater on hot and the fan on high.
Old 02-15-2015, 07:07 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Did you bother checking the coolant hoses to/from the heater core to see if you have hot coolant flowing?
Old 02-15-2015, 07:10 PM
kendall66's Avatar
kendall66
kendall66 is offline
thermostat stuck open?
Old 02-15-2015, 07:34 PM
Beachboss's Avatar
Beachboss
Thanks guys, ya I know the blend door moves because I opened the box and felt it move. I'll try flushing.
Old 02-15-2015, 08:32 PM
projectSHO89
Do the simple test in post #3. That way, you'll KNOW what to look for instead of just guessing.
jerryparks
2004 - 2008 F150
17
01-19-2019 08:24 AM
mrdamron2010
Modular V8 (4.6L, 5.4L)
03-23-2017 09:17 PM
tweak1029
1999 to 2016 Super Duty
03-28-2016 02:27 PM
Andrew Thomas
1997 - 2003 F150
01-15-2016 11:27 AM
mlelah
26
01-10-2015 02:27 PM
Quick Reply: No Heat need help!
