4.0 l lopes at idle when warm
Old 07-22-2003, 08:44 PM
butch t's Avatar
butch t
butch t is offline
Changed plugs on 4.0l as a PM. Since than check engine light on with lean mix code and engine lopes severely at idle when warm. At wits end-Ford garage has changed intake manifold gasket checked hoses, fuel pump and changed wires. Latest diagnosis is bad cam. Engines runs fine under load and no problem until plugs were changed. Any suggestions??
Old 07-25-2003, 01:03 AM
2000XLSExplorer's Avatar
2000XLSExplorer
2000XLSExplorer is offline
Did you check the gap of the plugs and also check to make sure you didn't crush the electrode closed on one of the plugs on installation.
genius117
30
06-24-2016 11:13 PM
rickm15752
07-04-2013 02:32 PM
rs-mn
1983 - 2012 Ranger & B-Series
08-26-2011 08:48 PM
1965joker
10-25-2010 12:18 AM
Nicholas1990
04-27-2008 07:50 PM
Quick Reply: 4.0 l lopes at idle when warm
