Yes. Radiator and condenser are going in bed at the tailgate area. Tailgate will have an actuator that opens tailgate bottom when ignition is on.ive seen many street rods with the radiators underneath the rides with less area to flow and cooling isn't an issue for them so should be much better with this setup.
Got the wheels last week and finally got time to post. Might look around for better sights as not much going on here unless it's a purist truck...but for now here's whats happenin'...
Those wheels definately go well with the overall pkg.
Many folks here, do appreciate originality, but craftsmanship and creativity are valued as well. There have been times that modified trucks were the main topic of discussion, things come and go. At any rate, thanks for sharing your progress.
Wiring will be after I assemble everything for the final time. I know where I need to run everything and took great notes on the donor truck. I used to build limousines for a living so wiring doesn't scare me one bit...the rack is an electric unit off a 2014 mustang and its mounted and looks awesome down in there with no hoses
