Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
What temp thermostat? 1989 4.9L I6
Old 02-15-2015, 05:21 PM
aj88V's Avatar
aj88V aj88V is online now
aj88V is starting off with a positive reputation.
My truck is barely blowing warm air and the needle isn't moving off cold.
When I check for thermostats, there are versions for 195*F, 180, and 160. Which is stock?
__________________
1989 F150 Lariat, "Bertie", 300 I6, M5OD. Working out the mechanics before the paint and body.
First Ford since selling my '72 LTD convertible. Nice to be back with family.
Old 02-15-2015, 05:22 PM
MR KROGOTH MR KROGOTH is offline
MR KROGOTH is gaining momentum as a positive member of FTE.
Go for 180.
Old 02-15-2015, 06:44 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Stock is 192 so you want as close to that as possible.
__________________
Paul (Conan) O'Brien
2006 E250 4.6L 4R75w 4.10, 2004 Ranger 3.0L 5-sp X-cab 4.10, 1994 Ranger 3.0L 5-sp x-cab 3.45, 2004 Subaru Legacy 2.5L 5-spd
1996 Kawasaki ZX11D, 2002 Honda VFR800,
Old 02-15-2015, 06:59 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to behold
Quote:
X2..........
__________________
2013 Ford Taurus Limited 3.5L
2006 Ford Mustang GT 5-speed 3v 4.6L
2002 Ford Explorer XLT 4WD 4.6L V8
rla2005@yahoo.com
Randy A | Central Illinois
Old 02-15-2015, 07:00 PM
rla2005's Avatar
Quote:
Originally Posted by MR KROGOTH View Post
Go for 180.
I disagree. ......
__________________
rla2005@yahoo.com
Old 02-16-2015, 01:53 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
Get a 190-195 degree T stat. The cooler units increase engine wear and decrease fuel economy.
Old 02-16-2015, 07:39 AM
dixie460's Avatar
dixie460 dixie460 is offline
dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.
You can go with any of the above suggestions. Anywhere between 180 and 195 is fine and won't hurt a thing... it's only a 15 degree difference we're talking. I like to put 180's in all my vehicles, no sense running them any hotter but at the same time it's still warm enough that everything works as it should.
Don't go down to the 165 or whatever the colder ones are, the engine does need to warm up to be efficient.
My 96 will go into closed loop long before the water temp gauge comes off the cold mark so no worries there with a 180.
__________________
96 F-150 SCSB - 351W - E4OD - Manual 4x4 - MileMarker Hubs - 3.55 Gears - 31x10.50x15 Falken All-Terrains - York 210 Air Compressor - 130A Alternator - Badlands 12K Winch - Dual Thrush Glasspacks - Full LED Conversion "Not One Bulb Left"
Old 02-16-2015, 09:03 AM
aj88V's Avatar
Thanks all. Went with the 195*F since that's closest to stock. Previous owner says he put in a new thermostat, but there's no guarantee it's working properly.
__________________
Similar Threads
thermostat mustang81 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 20 01-15-2013 04:10 PM
Changing thermostat PatChappell Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 08-01-2005 11:58 PM
thermostat HINLSEY Cooling, Heating, Ventilation & A/C 5 11-29-2004 01:12 AM
Thermostat for 390 fdels FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 06-29-2004 02:15 AM
Thermostat question BigMacZack Cooling, Heating, Ventilation & A/C 1 01-19-2004 01:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
