Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
New Dump Truck!!!!!
Old 02-15-2015, 08:46 AM
4x4slik's Avatar
4x4slik 4x4slik is offline
4x4slik is starting off with a positive reputation.
New Dump Truck!!!!!
So, bought the 76 F378 dump truck yesterday. Got it towed to my in laws place. Got the completely full tank of old gas drained and putting on fuel pump today. Hopefully this will fix the fuel delivery problem so I can drive it the 120 miles home. Will see if I can post pics from my phone.
Old 02-15-2015, 08:47 AM
4x4slik's Avatar
Old 02-15-2015, 08:58 AM
karjunkie's Avatar
karjunkie karjunkie is offline
karjunkie is starting off with a positive reputation.
Kewl, awesome grab
Old 02-16-2015, 11:35 AM
4x4slik's Avatar
Well, when I got to the truck, I knew already it didn't run, so we brought some gas and a battery. It was very cold, single digits with wind chill below zero. Hooked up battery, filled carb bowl with gas. Turned the key and it fired right up, ran good till the gas ran out. So I bought it.
Had it hauled about 20 miles to my in-laws house. Driver took a picture of it on his flatbed. After realizing the fuel pump seamed to be working, tried a few things to get it to run, but finally realized bad gas, a possible weak fuel pump just wasn't running the holley 4bl. So we pulled the canister off the fuel pump and drained the completely full fuel tank of its bad gas. We didn't pack clothes to work in the cold, so it was a very slow process. It was dark before we got all the bad gas drained so decided to wait till morning to push it into the heated shop. Found out later that the inlaws had to do a church coffee club thing in the morning and wouldn't be back till noon.
The boy and I worked on removing the old fuel pump in the - zero degree weather all morning. Got the truck pushed in the shop when my father in law got back and put new fuel pump on. Put some gas in and she was alive.
Pulled it out of the shop and tested pto and hydraulics, all worked great. Took the truck for a short drive, got back and smoke was coming from the engine compartment. ENGINE FIRE!!!. Got it put out and found a completely missing chunk of exhaust manifold gasket, which ignited old leaves and and grease on engine.
Back in the shop and off to the parts store. Got gaskets ,plug wires to replace melted ones from fire, plugs, cap, rotor and new 3/8th ratchet since my father in laws was missing several teeth. Broke 1 bolt off manifold and the others had deformed so no socket fit it right. Got pissed, partially because my FIL has crap for tools, and it was getting late. So I cut up gasket, shoved it into the giant hole and started for home.
Got about 10 miles and it started over heating. Got out and radiator is bulged and leaking at the seam. So, back to FIL for water and to let truck cool off. Put in water, pull start it and drive it back to FIL and park it, then headed home.
Will pull radiator from 74 and order carb kit, also return cap and rotor for the right one and head back up in a couple of weeks. Hopefully I didn't blow a head gasket or worse. probably also invest into a compression tester. Will also take along some tools. Was really missing my gear wrenches.
Old 02-16-2015, 01:06 PM
ZarK-eh's Avatar
ZarK-eh ZarK-eh is offline
ZarK-eh is starting off with a positive reputation.
Looks like it's time to build a tool kit for this ol' Work Beauty.
Maybe build a frame mounted box under the the dump for tools.
Old 02-16-2015, 02:24 PM
spotterjoe spotterjoe is offline
spotterjoe is starting off with a positive reputation.
Hope you got it for a good price as it sounds like a lotta work to make it reliable. Good luck!
Old 02-16-2015, 09:05 PM
bigzirb's Avatar
bigzirb bigzirb is offline
bigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud of
What fun is getting a new project if you don't start the adventure when you pick it up? Great fun and glad to hear your son was helping.
__________________
2001 Excursion V10 4x4 Auto 151,000 miles 285/75/16 BFG AT's, stock rims
2nd trans cooler and spin on filter, converted to electric fan (increased MPG by 1.1mpg towing) Trans temp gauge, Volt gauge, and Vacuum gauge mounted in 3 gauge driver pillar pod, Custom Safari Rack, Full size spare on the rack, Mag light at driver door, LED interior lights.
1978 Bronco 460, NP435, BW1345, Dana 44HD/ Dana 60, 40's "project"
Old 02-16-2015, 09:19 PM
martyanderson10 martyanderson10 is online now
martyanderson10 is starting off with a positive reputation.
Interesting story of revival. What are your plans for it?
Old 02-16-2015, 09:21 PM
earthquake68's Avatar
earthquake68 earthquake68 is online now
earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.
Cool score! Good luck and keep us posted.
__________________
Alan Fenstermaker
'73 F-100 360, 3 on the tree 2WD (Uncle Jesse's truck)
'75 F-250 460, C6 Monster Truck (Earthquake III)
'78 F-250 Ranger 514, C6 2WD(Soon to be Earthquake IV)
'79 F-200 300-6, 4 spd. 4x4 (Alice)
'79 F-150 400, C6 4x4 (Ka'Bluey)
Old 02-17-2015, 04:01 AM
oddfordjunkie oddfordjunkie is offline
oddfordjunkie is gaining momentum as a positive member of FTE.
Great way to teach the kid.
Aren't inlaws great, tired of working on their crap. haha
__________________
1978 F-250 CCSB 460-ZF5-D60
http://www.ford-trucks.com/forums/13...ld-thread.html
1961 Econoline 5 window pickup 144 I6
1985 E350 14" Box Van 6.9 IDI
1968 Dodge A108 Van /6
Old 02-17-2015, 07:56 AM
twinzilla twinzilla is offline
twinzilla is starting off with a positive reputation.
Cool truck, I have the driver's side door trim piece it's missing...if interested shoot me a pm
Old 02-18-2015, 09:38 AM
4x4slik's Avatar
Not sure on the forever plan. I bought it to haul rock for my driveway, and already have a few hauling jobs for it too. It needs a lot of work body wise. I really thing once I get all the little kinks worked out of the engine, it will be a strong runner. If I keep it, It will not be a restore job. It has some rust in some structure parts of the cab. Those will most likely just get reinforced with some ugly patch panels. I will fix it for strength and longevity, but not looks. My son is wanting to learn to weld, and this will be a good project for that. My neighbor is semi retired. He repairs heavy machinery for a highway construction company and is also a welder and machinist. My son has been working with him this winter a little and he has agreed to teach him to weld. Will hopefully have it home this weekend.
Old 02-20-2015, 06:13 PM
4x4slik's Avatar
Going after it again tonight. Got a plan and hopefully it works out.
Old 02-23-2015, 10:43 AM
4x4slik's Avatar
So, the saga continues. Got to the truck with some tools, parts and a plan. First was hoping it would start and the motor didn't get hot enough to seize. Success!!
Got it in the shop and started tearing out the radiator. New radiator is out of a 74 f100 with 302 c6 a/c. Everything measured out, 2 major differences, The transmission line connectors, dump truck is a manual, and how it mounts. The radiator from the dump mounts to a bracket toward the engine. The new one mounts to the radiator support direct, away from engine. Some slight cutting and moving clip nuts to the radiator fixed the mounting problem. Shroud from dump bolted right on and cleared well. Done for the night.
Sat morning I have a meeting till noon and pick up antifreeze and stuff for an oil change. Fill it up with coolant, change oil and filter. Off for a test drive. Pull it out of shop let it warm up so I can check coolant level, all good. Start up the road, go for about a 3 mile test drive, all seams fine. Get back, check everything out, no leaks all good. Now, up to the gas station to fill her up.
Gas station is about a 10 mile round trip. Get there fill er up all good. Start heading back all good till about half a mile to the house.It is missing and backfiring and won't hardly pull itself. Get it back and investigate. More of the manifold gasket is gone. My belief at this point is the plugs are getting to hot and fouling out. Decide there is no choice but to change it.
Since I noticed the gasket problem, I had been soaking with pbblaster. I had tried all the methods i could find on loosening these bolts. Well, nothing worked, I ended up busting all four top bolts. I decided to soak some more and not try removing broken pieces till morning. But decided pulling passenger side fender would be a good call. Someone made a nice set of brackets for front mud flaps. It is made of angle iron and bolts to the frame, it also has nice support bars attached to that. Only problem is it is mounted right center under the bottom bolt where the fender attaches to the cab. Very tired at this point so a BFH adjust it out of my way.
Sunday i run into town for some new bolts and various tools for removing broken bolts. The 2 bolts with threads left on broke off flush. Now the drill. After many hours of trying to remove pieces of bolt we redrill holes and tap it out. This really needed done anyway. For some reason, 3 of the top bolts were a different size than the rest, smaller.
Well the wifey is having some pain from what is believed to be a bulging disk, so it was time to head home.
Plan for next weekend is to clean old heat shield off of head surface, attach manifold, replace weeping frost plug and replace plugs and wires. Oh and of course reinstall fenders and hood.
Old 02-23-2015, 10:49 AM
4x4slik's Avatar
rust at cab and slightly bent mud flap bracket
new radiator installed
bolts for radiator accessed through grill
cool little power inverter, wasn't hooked up
Similar Threads
Truck won't shift back into 2H joegeds 1987 - 1996 F150 & Larger F-Series Trucks 6 07-02-2013 07:57 PM
1982 f350 dump truck 351w 1bad67sbf 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 05-23-2010 11:13 AM
dumps wizzard351 General Automotive Discussion 0 06-27-2005 02:27 PM
1966 ford dump vin code eedbl 1961 - 1966 F-100 & Larger F-Series Trucks 1 04-04-2005 06:59 PM
F250 Stock Dump Bed 1986f2504x4 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 02-07-2003 05:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
