48-50 gauge cluster customization
That looks really great. I think the white face gauges will look great in there.
I did something similar with the gauges in my 56. I also changed the bulbs to LED to brighten it up.
You can see it here: https://www.ford-trucks.com/forums/1...my-gauges.html
Thanks everybody! I figured with all i have learned from this site that i would try and finally try to add something of substance!
My spacing of the four gauges is right on. I also painted that white ring and i think it really makes a difference. I'm going to talk to the shop supervisor at school about cutting this pattern out. The next step will be fitting the speedometer in, but that will have to wait until the summer when I have some income.
That is looking great... Can't wait to see more... What are you thinking of cutting it out of? Can you show the back side how it looks? Wish I had someplace to cut something like that for mine... Need to start looking for old business cards to see if I can find a long lost friend.... You have a lot of talent, keep up the work
I have two ideas for what I will make the face out of. If I end up making it myself, I will just use some sheet metal to make it. If I get it cut out on a CNC mill, I will probably use a little bit thinker aluminum sheet, that way I could also add the radius on the openings like how the original plate looks. If I wanted to go over board, I could even get the cross hatch pattern cut into the face, but i think that would add a lot of machining time and cost to the part.
Gicknordon, man that looks great... I love the way it looks. I am working on a stock set right now but didn't like that I was going to have to problem with the org fuel gauge as I'm gearing up to install the Blazer k5 tank at the rear of my truck... I might steal your ideal... I was thinking of using my aluminum gauge plat and ask a friend to cut a piece of wood to mount over the aluminum.... Might have to rethink again...
#30
