Reciever Hitch Cargo Carrier?
Old 02-15-2015, 12:15 AM
A Rodder's Avatar
A Rodder
A Rodder is offline
When we went to disneyland a couple years ago, 1800 miles round trip, we utilized the rack but wrapped up the goods with quality black heavy weight garage / lawn bags. It worked well even thru a little slushy snowy weather.
Old 02-15-2015, 01:37 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
watch out for idiots backing into it. happened to me.
Old 02-15-2015, 07:37 AM
jspence105's Avatar
jspence105
jspence105 is offline
Originally Posted by Alex F
This:
how do you power them from the trailer hookup wiring? Is there a connector/etc?
I think someone did a write up on it here. I'll have a look for it. I basically just bought a trailer wiring kit and a roll of 12V red LED's I used two lengths one for the running lights and one for the stop/turn signals. If memory serves I used a 40 ohm 1 Watt resistor to dim the running lights.
Old 02-15-2015, 07:58 AM
jspence105's Avatar
jspence105
I can't find a write up on it. I bought the lights in May of 2013 so it should have been in and around that time. I bought 12V IP65 LED's from Ebay cut them to length soldered the connections and added the resistor to dim the running lights. If I happen to find it I will post it up here.
Old 02-15-2015, 09:04 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
I saw a van with one of these things on it. They must have had all the heavy stuff on one side because it bent down on one side and was grinding away on the road. I was waiting for it to completely break off.
Old 02-15-2015, 11:50 AM
pkthomas's Avatar
pkthomas
pkthomas is offline
I have a Rola bag I use on mine. It keeps everything dry and tied down.
Old 02-15-2015, 02:22 PM
Gene Horr's Avatar
Gene Horr
Gene Horr is offline
I've used the aluminum one from horrible freight. As is usual with their items the real world rating is half what they claim but otherwise worked well.
Old 02-15-2015, 02:37 PM
A Rodder's Avatar
A Rodder
A Rodder is offline
Spend fair money and get a decent one. Any hitch or truck accessory shop can get you one.
Old 02-15-2015, 07:42 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Originally Posted by Snowseeker
I saw a van with one of these things on it. I was waiting for it to completely break off.
Is that how u get yours ? 😝
Old 02-16-2015, 06:36 PM
Snowseeker's Avatar
Snowseeker
Well yeah, once an object leaves a vehicle its free for the taking no?
Old 08-15-2016, 02:04 PM
freesoul's Avatar
freesoul
freesoul is offline
Exclamation
I traded for this one, it wouldn't fit on a friends Jeep Liberty- not sure where he got it and never been able to locate one but this one is Excursion sized. Almost lost it to some thieves last summer at our lake cabin when I left it next to the garage but my wife and dogs were there at the time.
Old 08-16-2016, 09:26 AM
ithaca1230's Avatar
ithaca1230
ithaca1230 is offline
I've got a "Pro Series" 24"x60" 500lb one found it on ebay or something for $100 its been working great for 4 years now. Gets beat up quite a bit with heavy cooler and stuff on the beach. Added signal / brake lights that plug into trailer plug.
  #28
Old 08-16-2016, 06:07 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Great idea
  #29
Old 08-18-2016, 06:11 AM
1 Excursion camper's Avatar
1 Excursion camper
1 Excursion camper is offline
I built one. It holds well over 500lbs. I also put 2 lights on it. Becareful on the cheap ones.......they are cheap for a reason!
  #30
Old 08-18-2016, 06:33 AM
cameeks's Avatar
cameeks
cameeks is offline
Originally Posted by jspence105
They all work, but a cheap one if you don't use it often. I added LED light strips to mine for nighttime driving.
Had the same idea as you did.
Video
20130215_180557.mp4 Video by cameeks | Photobucket
I added this little throw together to dim the parking lights to match the tail lights and add signals. That's 2 more diodes under the shrink wrap.
Quick Reply: Reciever Hitch Cargo Carrier?
