Reciever Hitch Cargo Carrier?
Old 02-14-2015, 08:36 AM
NMSU_RRAggie's Avatar
NMSU_RRAggie
NMSU_RRAggie is offline
Anyone have a good receiver hitch cargo carrier they use? Going cross country with 4 adults and two kids this summer and will probably need a bit more carrying capacity.
Old 02-14-2015, 08:49 AM
xhid's Avatar
xhid
xhid is offline
I use this one to haul 5 gallon gas cans. Aluminum Hitch Cargo Carrier - 500 lb. Capacity
Old 02-14-2015, 09:16 AM
jspence105's Avatar
jspence105
jspence105 is offline
They all work, but a cheap one if you don't use it often. I added LED light strips to mine for nighttime driving.
Old 02-14-2015, 09:21 AM
NMSU_RRAggie
The lights are powered by the trailer hook up?
Old 02-14-2015, 09:28 AM
NMSU_RRAggie
Can you open the doors with the carrier full?
Old 02-14-2015, 10:31 AM
jspence105's Avatar
jspence105
Yes I plug it into the trailer wiring. It depends on what I have on the rack it I have smaller items tot he back I can open the barn doors but when I'm loaded up for a week they will not open. Just hope not to get a flat tire. The lift gives you OK access to the back I keep a 12v cooler back there and have no issues getting to it.
Old 02-14-2015, 10:36 AM
05MilMachine's Avatar
05MilMachine
05MilMachine is offline
I got one made for 4 bicycles at northern tool. Lay the bike hoops down and its a typical hitch carrier. There is a pic of it in my album I think. It is very sturdy and holds engine blocks just fine, but its also very heavy so if your moving/using it a lot, maybe aluminum would be better. I used it on the wife's Mountaineer for a vacation and it worked great as it sits far enough back to let you stand there and open the hatch.
Old 02-14-2015, 10:38 AM
Alex F's Avatar
Alex F
Alex F is offline
This:
how do you power them from the trailer hookup wiring? Is there a connector/etc?
Old 02-14-2015, 10:57 AM
gots_a_sol's Avatar
gots_a_sol
gots_a_sol is offline
On my dirt bike carrier, I just wired the lights to a normal trailer plug (with the Ex I need a 7 to 4 pin adapter)
Old 02-14-2015, 05:13 PM
High Cetane's Avatar
High Cetane
High Cetane is offline
Be careful if it is a "Folding" carrier. My B-I-L had one and the hinge point was sloppy from day1. The result was horrendous rattling & clunking whenever it was used.
If it'd been mine, I would have welded it solid.
Old 02-14-2015, 06:58 PM
ithaca1230's Avatar
ithaca1230
ithaca1230 is online now
Got one we use quite a bit 24" x 60" 500 lb capacity think its pro com or something like that off of eBay for around 100 bucks added lights to it. it works great I can post a pick if you want
Old 02-14-2015, 07:02 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
I picked one up from walmart for about $100, it's worked well for a few years now.
Old 02-14-2015, 07:22 PM
A Rodder's Avatar
A Rodder
A Rodder is offline
I use the Curt ones. 24x60 inch with the 6"or so railing. They have some that come straight out of the hitch. I prefer the one that comes out and kicks up about 4" or so. It folds up as well.
Old 02-14-2015, 09:58 PM
wpnaes's Avatar
wpnaes
wpnaes is online now
They work great; trailer out back; firewood up front.
Watch for sales at Trailer.com or Harbor Freight.
Old 02-14-2015, 11:52 PM
NMSU_RRAggie
I am definitly thinking the larger 60", I am still on the fence about the folding option. I also like the 6" rails.
Any experience with luggage getting overly dirty if not in wet, muddy, snowy conditions?
Quick Reply: Reciever Hitch Cargo Carrier?
