truck won't start
02-13-2015, 06:11 PM
on
truck won't start
I have a 03 four wheel drive. I was going down the road about 35 or 40 mph. The truck kinda sputtered for a few seconds and won't start now. I changed the fuel filter. The ipc is reading 0 with the key on and up to 158 while trying to start it. Could it be the ipc? I unplugged it and it iz full of oil.
02-13-2015, 07:09 PM
Will it crank with the ICP unplugged?
02-13-2015, 07:12 PM
on
Quote:
Originally Posted by
AllaboutMPG
I tried once and it wouldn't.
02-13-2015, 07:35 PM
Check the tin nut on the back of the Ipr.
02-13-2015, 07:54 PM
Dash lights functioning normally? What are you using to read ICP? Can it pull codes? Can it watch IPR % while cranking?
02-13-2015, 07:59 PM
on
F350-6
Yes the dash lights function normally. I am using a scan tool it is not showing codes. I will have to see tommorow if it can read ipr while cranking
02-13-2015, 08:14 PM
What is the oil level. have you ever changed the CPS
02-13-2015, 08:15 PM
No codes at all? Trying to crank with the ICP unplugged should have at least tripped a P1280.
02-13-2015, 08:17 PM
on
F350-6
IPR is 14.84 with key on and 32.42 while cranking.
02-13-2015, 08:19 PM
on
F350-6
I will have to check for codes again.
02-13-2015, 08:25 PM
bulldog88
Just a steady 32.42 the whole time? Can you hear the fuel pump come on with the key?
02-13-2015, 08:28 PM
on
F350-6
Yes just 32.42 then back to 14 when I let off the key. I can't tell about the fuel pump I hear stuff under the hood come on.
02-13-2015, 08:46 PM
Your PCM isn't telling your engine to try and start. Can you monitor RPM while cranking with the scanner? Check your fuses. Check for worn wires that may be shorted to ground below and behind the 42 pin connector. Check the wiring at the ICP sensor and IPR to make sure the wiring isn't chaffed. And the WTS light and all other dash lights go on and off like they're supposed to in the proper amount of time?
02-14-2015, 12:27 AM
Plenty of good stuff to look at so far! I'll toss out a couple more.
The fuel pump is located on the frame rail under the drivers door, you should hear it run for 20 seconds or so when you first key it over.
Does your tach show RPMs when you try to start?
02-14-2015, 07:05 AM
on
aawlberninf350
No the tach does not move when trying to start.
