signs of a bad icp?
02-13-2015, 04:23 PM
on
signs of a bad icp?
What are the signs of a bad icp sensor?
02-13-2015, 08:19 PM
Quote:
Originally Posted by
bulldog88
Slow build up signal
Oil in the plug
lower than..... 450 at idle warm
Voltage outside .25 - .30 VDC KOEO
Bla Bla Bla.....
What are you experiencing?
Any of the above may relate to other issues. The ICP is just a part of t
02-13-2015, 08:25 PM
on
whitetmw
he system.
Oil in the plug
Bla Bla Bla.....
It just quit going down the road. And won't start now. Someone said possibly ipc
02-13-2015, 08:44 PM
02-13-2015, 08:46 PM
on
Dan V
How's the oil level?
About a half quart low
02-13-2015, 08:53 PM
on
Is it okay to run it with a disconnected ICP?
02-13-2015, 08:56 PM
bulldog88
Is that below the Full line or below the Add line?
02-13-2015, 08:57 PM
on
jhl3
Below full line
02-13-2015, 09:00 PM
Kocobeam
yes. But, not as a solution to a problem. If it starts unplugged, it needs to be replaced.
02-13-2015, 09:06 PM
on
whitetmw
So if it still won't start with it unplugged it's not bad?
02-13-2015, 09:20 PM
bulldog88
Not necessarily. Do you have any of the symptoms described above?
02-13-2015, 09:25 PM
When you are attempting to start the engine and it is turning over, does your tach respond?
02-13-2015, 09:28 PM
Bulldog, what year and vehicle are you dealing with?
02-14-2015, 12:17 AM
on
whitetmw
Thanks, sound advice.
02-14-2015, 06:01 AM
on
jhl3
When I unplugged it the pluv was full of oil.
