What's my redline?
My 08's tach I believe goes to 6k without a redline indication (red marks). Would assume past that range would be self destruction time.
People seem to say running it at 4000-4500rpms is not an issue. I've been at those rpms pulling heavy loads up a hill but try not to be there too often otherwise.
Can't imagine hitting the rev limiter on my truck.
I've wondered the same thing but with an automatic transmission behind my 06 v10 I very much doubt that the rev limiter could be activated unless you locked it in A low gear.
The max I have ever seen my 3v v10 turn was very close to 5000rpm pulling 14 tons of hay going up a short but very steep grade I had to see what the v10 could do. Only did that once but boy did it pull!
I don't know what I did with my original paperwork, but here's how I figured my ~5200rpm number.
The physics behind a redline has to do with the mass that's flying around inside the engine. Rev it too high, and bad things start to happen.
The metric I've most often seen referenced when determining a redline is "feet per minute", which is the total distance an individual piston travels as it's going up and down.
The feet per minute maximum for a typical street engine is 3500-4000. A "modified" race-oriented street engine is somewhere in the 4000-4500 realm. And a full on race engine is 5000, maybe a bit more.
(Someone's going to ask where I got these numbers I'm sure. I don't specifically recall, but they do stick in my mind.)
For the 6.8L V10, I used a 3700 feet per minute figure.
3700 feet per minute = 44,400 inches per minute
V10 stroke ==> 4.125 inches
1 revolution = 1 up stroke + 1 down stroke = 8.25 inches
44,400 inches per minute / 8.25 inches per revolution = 5381 revolutions per minute
I have no problems letting my engine go to 5000rpm. I've been at that point, though I try not to do it too often. I won't let it go beyond that, though.
Maybe I misunderstood your math, but I can tell you with all certainty a V10 will reach 6,000 rpms. I don't recommend it, but mine has done it a couple times for giggles. Also not sure where you get the "modified street engine" and "full on race engine" figures from but my flat-tappet cam mild 302 in my '68 Mustang will pull to 6,000 with ease and the roller cam motor (stock) in my old '88 Mustang would easily hit 6,800. I didn't even need to break out my calculator for that
The destruction RPM is above what the PCM will allow the engine to run. There is a rev limiter that will turn off the injectors at the set point. No, I don't know the specific RPM for a 2002 V10.
There's an easy way to find out. The limit is set at a still-safe RPM, so put the pedal to the metal and see where it stops.
