Simple valve cover is killing me...
Old 02-12-2015, 03:51 PM
FilmCarp's Avatar
FilmCarp
FilmCarp is offline
Hi,
Many of you have been very helpful with my 84 f250 302. So here goes; I got the truck running pretty well in my driveway but I noticed I was spooging a lot of oil out of the valve covers. General wisdom after searching here was to replace them, so I ordered a new set. Now, the passenger side one is kicking my butt trying to put it on. I have the emissions components on one side binding me and the manifold hot air valve catching the flange on the inside. The old one popped off with just a bit of prying, but I cannot get this one on. Is there any trick to this short of removing that hot air valve? Am I the only one who has had trouble with such a simple procedure?
As usual, thanks for your patience.
Old 02-12-2015, 06:24 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,654 Likes on 1,337 Posts
Are you trying to install the factory covers with new gaskets or aftermarket covers? Aftermarket covers may require modification. It's amazing what the aftermarket sells to fit vehicles and they do not come close to fitting.
Old 02-12-2015, 07:26 PM
FilmCarp's Avatar
FilmCarp
FilmCarp is offline
Both the original and the new one are fighting me. The old ones looked deformed so I bought these. Drivers side went right on. Its just getting around the pinch point that is killing me.
Old 02-12-2015, 09:32 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
I would just disconnect the hot air tube from the carburetor.
Aaron-71
27
03-21-2016 10:53 AM
red rock 78
06-26-2010 05:53 PM
Hillbillydeluxe
02-21-2005 06:30 PM
in_utah_not_of_utah
01-21-2003 09:35 AM
Quick Reply: Simple valve cover is killing me...
