Getting responses
Getting responses
I'm new to the forum so I may have missed something. I asked a question about transmission swaps a few days ago and have received no responses. The question may have been answered. If so I didn't locate the answer.
My question is, is there some kind of initiation ritual I must go thru before I can get a response? If so would someone please enlighten me?
It is quite likely nobody here knew the answer
There are so many changes on these transmissions so do your research before the swap.
You might try in this part of the forum
Clutch, Transmission, Differential, Axle & Transfer Case - Ford Truck Enthusiasts Forums
Hopefully a transmission guru can help you out.
Good luck and welcome to the fte
