99 psd 7.3 super duty snap on solus cct test questions - Ford Truck Enthusiasts Forums
Old 02-12-2015, 10:31 AM
f350hammer's Avatar
f350hammer f350hammer is offline
f350hammer is starting off with a positive reputation.
Hey guys. Thanks for your time!
I have been having injector issue out of my truck...... The problem has been there since I got it..... I'm really starting to worry about this sneaking up on me and biting me in my butt.....
The issue is - when cold below 50s [thr colder it is the worse it is]
the truck has a miss fire - in order to get rid of the misfire you have to let it warm up for about 5 to 10 mins [depending on how cold it is] once the temp gauge is in the normal area you have to wot it once and it will clear up - it won't completely go away until you drive it [ you basically have to wot it in gear one good time and it's gone] [1/4th of a block] and won't fully return until complete cool down......
The other day I let it cool down a bit and pulled the valve cover on the passenger side. I pulled the plug for each injector - one at a time and independently and reconnected - trying to find the bad injector........ starting from the radiator/drivers side.....
The 1st injector made some difference
the 2nd made a huge difference -
the 3rd made some difference-
the 4th made no difference
Up to operating temp they all made a huge difference......
Iv also been seeing over 20mpg on the highways.
Only issue is when it's cold.
I wanna run a cct test on the truck just to see what the code reader will say - my buddy has a snap on solus and will read the codes for free..... The problem is he doesn't know how - we have been told it will do a buzz and cct test. Could someone inlightin us on how to do such? Any thoughts or ideas!
Iv got a bud who can rebuild the injectors for my truck - he said worse case around 90$ an injector..... but it will require me to shut the truck for a few days and I can't do that..... I'm on the hunt for a few ab injectors cheap pm me if you got any you wanna let go of cheap or maybe trade for...... iv got a lot of family issues going on right now and I'm carrying more then my share - supporting 5 others on just my check...... so I need to make sure I don't get taken advantage of or for a ride..... I need this truck fixed properly. Thanks guys - any advice.
Old 02-12-2015, 12:23 PM
David7.3's Avatar
David7.3 David7.3 is offline
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
When you put your info into the soluus go into generic mode, there you will see a bunch of test you can do, thats were the CCT is, sounds like you got a couple glow plugs out, or the UVCH Valve cover harness is bad, you can unplug them and command the GPR on with the scan tool and make sure your getting 12volts to the glow plugs. I'm betting on glow plug related, you can ohm them out at the connectors just unplug the connector at the valve cover, the glowplug terminal is the big ones. Take and OHM meter and ground one lead, and touch each glow plug terminal should be 5-6 ohms depending on temp. If it reads infinity glow plug is open, done, gone, then you can pull the valve covers and test the glow plugs again with the harness unplugged still not 5-6 ohm, you know you have a bad glow plug, if you now have a good reading UVCH el garbago. Look for codes while your in there, make sure your oil temp and coolant temp are close, thats what the PCM uses to activate the plugs. good luck
Old 02-12-2015, 10:54 PM
f350hammer's Avatar
Quote:
You really think this is glow plugs?
i thought the glow plugs only ran for 2 or 3 mins max...... This miss fire remains for 10 mins or until in the warm rang or more until and you drive it -wot it. I'll test to glow plugs before i do anything. Thanks bud
Fishbone help - engine knock cangim 1999 - 2003 7.3L Power Stroke Diesel 3 11-06-2016 06:23 AM
Engine firing order and cct and perdels. Fefanatic 1999 - 2003 7.3L Power Stroke Diesel 13 08-19-2016 07:48 PM
AE or spare IDM in Seattle? I'll buy dinner and beer. lemonshindig 1994.5 - 1997 7.3L Power Stroke Diesel 1 06-14-2014 10:11 PM
Cct results always changes 84-250 1994.5 - 1997 7.3L Power Stroke Diesel 4 09-22-2013 05:42 PM
Anyone ever run a Cylinder Contribution test with a Snap-On SOLUS ULTRA? MobeyDick 6.0L Power Stroke Diesel 0 01-01-2012 04:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
