Turning over but won't start
I haven't had my 1977 F-350 with a 460 for long, but it was starting and running. About a week ago it started only turning over but not catching. Fuel pump had been leaking so I replaced fuel pump and fuel line. I can see that the carburetor is getting fuel, but still no start. Replace the ignition module, & coil but still no start. Next I think I will check the plugs and replace them and replace the distributor cap and rotor. Any other ideas?
In a word: diagnostics.
Sounds like you're on the right track in a round-about way by servicing components vital to a running engine - fuel delivery, spark, etc. However by omission one can only speculate whether or not you have actually checked to see whether or not any of the systems you're changing are working.
With that in mind, have you checked to see if you're getting spark? If you are, then changing the cap/rotor likely isn't going to fix it.
