need 460 towing performance upgrade ideas
i have a 94 f350 duelly that i use to tow a goose neck rig on weekends. the heads are coming off this winter [needs a valve job only have 82k on motor but almost all towing miles] so with that in mind what can be done to improve performance without spending to much. i want to try to stay under 1500 for parts. i'm afraid if i make too much power the E4OD will need rebuilt [again]
This should be a sticky it comes up so often.
Free:
Timing set to 12-14*
Remove intake restricter (there is some debate on this)
Cheap:
Adjustable fuel pressure regulator (set to aprox 45-47 PSI @ idle)
new plugs/wires/cap/rotor
Free flowing exhaust, ex. Magnaflow cat and muffler
Electric fan
Headers
Cam, intake and heads
Stroker
Supercharger
Some searching here will help
https://www.ford-trucks.com/forums/forum53/
Free:
Cheap:
Electric fan
Headers
Stroker
Supercharger
Remember, pre power stroke the 460 was the goto tow engine. It's got more HP and TQ than the IDI.
The exhaust side of the head is where the biggest gains are. Open them up to 1.76 or 1.80 and do a good multi angle valve job.
Free:
Cheap:
Electric fan
Headers
Stroker
Supercharger
Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) - Ford Truck Enthusiasts Forums
Free:
Cheap:
Electric fan
Headers
Stroker
Supercharger
I have 160k on the 460 in my f350 with a ZF5 speed
It has the Banks Power Pack on it and the rest is stock. the most I have pulled with it is 9k and it did it with ease.
I would suggest adding a set of headers, and a good 3 inch single exhaust. Then couple that with some work on the heads and you should be set.
The biggest change in seat of the pants to me was a well designed 3" exhaust with Magnaflow cat and muffler. I have it turned out in front of the rear tire.
Timing was next best feel.
Literally the definitive guide for achieving power AND mileage in a big/ heavy truck with the 460:
FOUR WHEELER Magazine's Project M.P.G.
Project MPG.
Project MPG.
Project MPG.
Project MPG.
I love how the K&N snake oil people said that the hot underhood air was not a problem LOL
Classic read that I have read many times. Glad the magazine folks went back to the stock airbox, there is nothing wrong with it.
So When I first got my ford I had one of my Techs at work put a steering box in it, while I worked on the wiring issues. well he removed the snorkel from the air box to the front of the truck. And I do have a cleanable air filter (Whatever brand Banks uses) Well when he was done he never reinstalled the snorkel, and it for some reason got put in a parts room.
Well last weekend I pulled the truck into the shop and was checking fluids and noticed the snorkel was gone. Found the snorkel and reinstalled. the next day I put 734 miles on it heading up about an hour north of seattle. The truck picked up .5 MPG as compared to the last trip I took down to California. which is pretty good seeing that the seattle trip had twice the traffic jams and my Average speed was higher. I am interested to see the MPG average after my next trip to Sacramento so I have similar driving conditions to compare
Just my first hand experience with keeping the Intake Air Temp down.
97FordF250
10-23-2010 11:31 AM
97FordF250
10-19-2010 03:51 PM
dude74crew
02-24-2008 05:50 PM
CHRISRA
03-15-2006 05:27 PM
wtrskiier
01-02-2004 06:03 PM
