1989 f150
1989 f150
So i picked up an 89' f150 this past weekend with a 5.0 in it. i gotta redo the break lines since it has no breaks. i got it for 500 the guy drove it a few miles to where we met so it does stop. The passenger side breakline is leaking so im hopeing it's just sucking air in and not working. The motor and tranny were rebuilt in 2010 so after i get it on the road and stopping im going to start doing mods to the motor. It is a rough looking truck, it looks like an old farm truck so im going to keep it looking rough and just build the motor and what not. wish me luck i will post pics later
I can't remember, does this truck have shoe brakes in the rear? If so, you will need a brake spoon to adjust the resistance as well. Check around your booster and see if there is any leakage also, as you could be losing pressure there as well. Also, look at the lines coming off of the booster. I had a Suburban that cracked a brake line, after I replaced it, I took the truck out for a test and as soon as I stepped hard on the brakes, I blew a line from the booster. Replaced it and truck braked fine.
pacrewchief
17
07-04-2009 06:44 PM
76CamperSpecial
05-29-2008 07:59 AM
Scott Fraser
06-14-2004 04:51 PM
