Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Timing Advance Issue: 1957 F-800
Old 02-16-2015, 08:41 AM
hiball3985's Avatar
hiball3985
hiball3985 is offline
Go back to to square one, put your timing light on it and start bring the RPM up and see if you are getting any advance at higher RPMs. If not it's probably the vacuum advance unit. Replace that if needed first and then recheck. If there is still no advance it could be something in the govenor, which I have no idea how that works.
Old 02-17-2015, 06:19 AM
Slowpoke Slim's Avatar
Slowpoke Slim
Slowpoke Slim is offline
It is very common for the vacuum diaphrams to dry out, crack and leak vacuum. The best way to test this is with a hand vacuum pump with the engine running and watching a timing light. I know you said you don't have a hand vacuum pump.
I would fully expect that the diaphram is shot, and it needs replacement. You may be able to find a replacement diaphram kit. Back in the day of points distributors and vacuum advance, it was a normal part of the tune up procedure to test the diaphram.
Old 02-17-2015, 08:06 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
He did mention in the OP that as engine RPM increases advance does not.
So there's still the issue of mechanical advance. I think. Is "tach drive" a different name for a vacuum-only advance distributor, though? Load-o-matic was another.
Old 02-17-2015, 11:16 AM
hiball3985's Avatar
hiball3985
Tach drive means it has a cable driven tachometer.. It appears his has no mechanical advance like a "load-of-crap" model, vacuum only.
OOPs I missed where he said it didn't advance with higher RPM..
Old 02-17-2015, 11:39 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Ah, OK... So the tach, while nice to have isn't a factor here in the advance mechanism problem. A '57 distributor should have a dual advance type distributor. He should be able to at least clean everything up and make sure the breaker plate slots, springs and weights aren't gummed up or seized. Vacuum advance can can be repaired as someone mentioned.
Old 02-17-2015, 12:02 PM
hiball3985's Avatar
hiball3985
These large truck distributors are a totally different animal, nothing like a Y block. The vacuum units can't be repaired, they are a sealed unit, you just replace it..
Old 02-17-2015, 02:49 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
If not a vacuum only unit though, should have centrifugal weights and springs? I dunno. You're right about that.
Old 02-17-2015, 05:27 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
OP says when he sucked on the vacuum tube, nothing moved. Change the diaphragm
Old 02-17-2015, 05:52 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
True that, but he's not getting any mechanical advance either, that's the killer.
Old 02-17-2015, 06:08 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
As the original poster (OP) said here: https://www.ford-trucks.com/forums/1...l#post15090585
He has no mechanical advance to worry about...
Old 02-17-2015, 07:29 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Well OK.. Converting to a dual advance distributor would make sense if practicable.
acfd
02-10-2015 01:11 PM
1986F150six
08-28-2012 12:46 PM
6fifty_f1fifty
06-08-2010 06:03 PM
Bart8109
01-16-2009 02:02 AM
towtruck
01-25-2004 06:21 PM
Quick Reply: Timing Advance Issue: 1957 F-800
