94 F350 Spring question
Sorry if this is a repeat. As far as I can tell these springs are way to big for this truck. Its a 94 F350 with a 8" lift on 37" tires. I know the rids should be ruff, but man this ride is very hard. I've looked through out this website and others and mine seems to be the only one with springs this big. The question I have is it safe to remove some leafs to soften it up? Or am I just better off redoing my suspension? Thoughts?
The front would get a RSK and the rear just needs the hangers drilled out to accept the larger SD hardware
Have a read
https://www.ford-trucks.com/forums/1...l-fab-rsk.html
Have a read
Wow, so much misdirected effort went into that.
The multiple lower rear shock mount is interesting but worthless without a top mount solution.
In one pic there are two front shocks visible, in another pic, only one is visible?
Dang, those front springs look just like the rear leaf springs. Like dump truck springs.
But, I would NOT just starting removing leafs, this could likely lead to the breaking of the remaining leafs. Get the proper leaf spring pack for your needs.
Received 3,101 Likes
on
That is a truss, and looks to be a nicely done one. It makes the entire axle stronger.
You could use stock springs from a Super Duty and a 4" RSK on the front.
www.sky-manufacturing.com - 9297FordSuperDutyLeafSpringConversionShackleRevers al
You could use stock Super Duty springs in the rear with a shackle flip.
www.sky-manufacturing.com - 7897Ford4x4RearShackleFlipLiftKit45
You will need a 4 degree taper block to point the pinion back down.
Warrior Part 800066 - Leaf Spring Shims - 4 Wheel Parts
This will get you sitting nice on 37s and ride awesome.
on
I know of nothing you will need to do to your driveline if you use the 4* taper shim to point your pinion back toward the ground. (unless the previous owner put in longer driveshafts, which I doubt)
Those are the heaviest looking springs on the front of a 1 ton I have ever seen. I bet it would not flex with another truck sitting on top of it.
on
The angles shim is required if you do a rear shackle flip. Moving only one end of the leaf spring pivots the axle.
But, if you just use the stock F350 4x4 rear block, which is 4", you will be about level with a short RSK and U or V code springs. Stiffer from springs or a taller RSK and you may want a taller block.
I think a quality rear shackle flip is stronger than the 4" block. But, lots of F350s came from the factory that way and the block way is the least amount of work.
