Timing Adjustment
1. Hook a timing light to #1 spark plug wire.
2. Mark the damper at 10 deg BTDC.
3. Remove the SPOUT shorting bar jumper.
4. Loosen the hold down bolt for the distributor.
5. Start the engine
6. Aim the timing light at the timing pointer.
7. Turn the distributor until the mark on the damper lines up with the pointer.
8. Tighten the hold down bolt.
9. Recheck the timing mark.
10. Put the SPOUT Shorting bar back in.
11. Check that the timing has moved.
12. Turn off the engine.
13. Remove the timing light.
5. Start the engine
turnkyle
08-12-2012 08:44 AM
THE BLUE HEAP
03-13-2010 07:10 PM
