GAS TANKS
I'm going with a mustang tank, I think.
Some good reading here: Frequently Asked Questions (FAQs) on Adapting Major Components of 1948 to 1960 Ford Trucks - Ford Trucks
Received 4,132 Likes
on
I'm doing a frame swap from a 1998 Ranger and the gas tank is 20 gallons (ext cab). I believe the fuel lines at 5/16 but you would need to upgrade the pump if you've got a lot of HP. The driver's side shock would have to be relocated from forward facing to axle to rear facing. Since the frame span from left to right is about the same as my 1950 F1 it should fit between the left frame and the driveshaft of the original frame. Also the front crossmember may have to be modified. The tank is plasic, so it will clean out with soap and water - I know this. Just get measurements at the yard first.
on
