I need to replace the mounting brackets on the body of a 1964 F-100 Cab.
I can't find any replacement mounts for the 64 I find them for the 65-66 but they are considerably different.
Neither LMC or Carpenter list them.
Any other sources?
the original question sounded like he was looking for replacement mounts for the cab, not the frame
there are more original looking ones avalible for the later cab like he said
theese would look just fine under my custom uni
I used a set of these replacement mounts from Carolina Classics on my '62 uni. They are identical to what Ford used but much heaver metal. The only problem is you have to add the anti crush tube to the mount. Other than that they installed with no issues.
