Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Aftermarket Brake Booster
Old 02-10-2015, 08:22 AM
544tess 544tess is offline
544tess is starting off with a positive reputation.
So my '54 F250 came with an aftermarket brake booster mounted under the floor on the drivers side frame rail.
To get the reservoir cap,you have go to underneath the truck to get to it.There might be 2 inches of clearance.
Anyone with this set up?
Did you cut a hole in the floor for access?
Old 02-10-2015, 09:53 AM
jimcar-9 jimcar-9 is offline
jimcar-9 is gaining momentum as a positive member of FTE.jimcar-9 is gaining momentum as a positive member of FTE.
There is a remote filler cap available from wildwood I belive. You attach that the the reservoir and place the remote filler easily accessible.....
Old 02-10-2015, 10:39 AM
willymakeit willymakeit is offline
willymakeit is starting off with a positive reputation.
I bought one from Summit I believe. 89.00 plus shipping.Ran the dual lines thru the floor where the gas tank was in my 56. Used a grommet and built a mount.
Just filled and bled the brakes on a new system last Sat. without any problems.
Summit has free shipping to.
Old 02-10-2015, 09:14 PM
Thanks for the info.
Similar Threads
1952 F1 Under floor brake booster and master cylinder oscajo 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 10-19-2013 02:05 AM
Brake Booster Help 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 05-01-2006 02:29 PM
Brake booster replacement 78custom 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-23-2003 08:51 PM
brakes seymour 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 08-17-2002 11:41 PM
Brakes AaronW 1973 - 1979 F-100 & Larger F-Series Trucks 3 06-15-2001 03:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
