Super Duty running light issue - Ford Truck Enthusiasts Forums
Old 02-09-2015, 08:41 PM
AGGRO AGGRO is offline
AGGRO is starting off with a positive reputation.
One of my outside roof lights quit. I replaced the bulb and it's still down. These are all on one fuse right? 2001 is the year. Any ideas appreciated.
Old 02-10-2015, 07:55 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
All of the running lamps are in parallel off one fuse. If only one light is out, then the problem is with that lamp fixture, its ground, or its wiring back to the splice.
Check the lamp socket for corrosion, check the ground, and check continuity of the power feed back to the adjacent light. One of those circuits is open (unless you installed a defective or bad bulb or it's installed wrong).
Old 02-10-2015, 11:35 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Corrosion is usually the issue here.....
Old 02-11-2015, 11:44 AM
Thanks guys, i'm checking with my meter today. I did notice that the sealer they use around the cover deteriorated and water can get in there. I'll check for power before I decide to swap out the fixture.
Old 02-16-2015, 04:03 PM
Ok, got juice so I cleaned it up and got the ground going again. I'll have to get some type of sealant to keep the water out so it doesn't happen again, at least as long as possible.
All good!
59 Ford F600 Brake Lights Kitty Chandler Carr 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-02-2016 12:18 PM
94 f150 XENON lights FordRun 1987 - 1996 F150 & Larger F-Series Trucks 2 01-08-2015 09:45 PM
Dome Light Question 84StraightSix 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 08-31-2014 12:35 PM
LED or HID head lights and tail light ? farva66 1987 - 1996 F150 & Larger F-Series Trucks 9 08-29-2014 02:17 PM
Svt Lighting Badges?????? rangersvt04 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 4 09-09-2007 11:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
