Radio help
Wires are new 9mm Ford Racing along with new MSD coil and cap/rotor. Did it before the ignition upgrade also. I don't believe it really changes with rpm, but I haven't really left on very long like that. But clear and strong when engine is not running.
If your antenna lead is original it could be bad, check your grounds for your sound system. I put in a power line filter inline with the positive voltage connection to the stereo and it fixed 95% of static. Also I properly grounded the radio to the chassis on clean fresh metal, and I made sure my engine block ground was good. Also if you have a high power alternator you could be getting alternator whine. Mine got worse after replacing the 2g 65a with a 3g 130a.
Your local mobile stereo shop either will make one or has them in stock. Basically a torrodial transformer
on
people still listen to am radio?
i installed a jvc head unit,4 pioneer 4-way speakers and a rockford frosgate 4 channel amp in chip truck back in 2010-11.sounds super sharp and clean but after the amp install i got alternator whine.i installed this one here and it cured it:
but it's got a mixed bag of results.for the price i gambled and it payed off.don't hate me if it doesn't work or you too lol! like GJ says though,you can pick these up at like radio shack too.it's worth a try.
Here's the kicker for me, when i tune into my favorite AM station, I get two stations at the same time. I hear one the main station and then the other garbled in the background.
I think its the radio. It's a digital one, so there is no in between manual adjustment.
alvald83
06-17-2010 03:52 PM
Shane in WI
18
08-08-2009 07:37 PM
