2011 F250 4x4 6.7 transmission leak
Made a short run to get lumber yesterday and when I got home the truck smelled hot I checked it out and found a transmission oil leak at the rear of the transmission in front of the transfer case. can not really see what is leaking only has 22,000 miles anyone else have this problem or know what may have happen.
Crystal
Crystal
2011 Ford F250 transmission leak
just got back from having the truck check out, they found transmission oil pan bolts loose and tighten them, they made note to check on next service.
I am going to wash down when its warm enough to do so with out everthing under there turning to ice and keep a eye on it.
First new Ford truck I have ever owned did not want to think I was going to have problems with it. I have had quit a few used ford truck with little or no problems, just did not want my retirement truck to be different.
THANKS Crystal for your response that made me feel better.
Crystal
2011 F250 Transmission still leaking.
Well Truck transmission is still leaking have an appointment in the morning to check it again. I had clean the oil off and was keep a check and got under it and had oil dripping again looks likes it coming from above the oil pan. Just thought I would keep you informed.
Crystal
Crystal taken the truck back to Glockner Ford South Point, OH and had it checked again and they allowed me to look at with them on the rack and it does look like the transmission pan look it is what is leaking and blowing up on the back of the transmission. They just called and they gasket is in and I am to take it back Monday morning for them to install it. My phone is 740 532 3050 if you need to talk to me.
Crystal taken the truck back to Glockner Ford South Point, OH and had it checked again and they allowed me to look at with them on the rack and it does look like the transmission pan look it is what is leaking and blowing up on the back of the transmission. They just called and they gasket is in and I am to take it back Monday morning for them to install it...
I don't have the ability to reach out to folks via the phone; if you don't have PM access yet, I recommend calling our Customer Relationship Center at 1-800-392-3673. They have the same ability to assist that I do. Additionally, I recommend editing your public post to remove your phone number.
Crystal
back to South point Ford
new transmission gasket did not fix leak taking it back this morning to see what they can find now, [
QUOTE=FordService;15190745]Hi ford48,
Crystal[/QUOTE]
Crystal[/QUOTE]
Crystal
update
This time they are saying the leak is coming form the tail shaft not the pan and have ordered gasket and seal will call when they come in to set up repair date.
QUOTE=FordService;15316529]Thanks for the update, ford48; I'm glad you're getting this back into the hands of your dealership. Come back and tell us how your appointment goes. I'll be here to assist, if needed.
Crystal[/QUOTE]
Crystal[/QUOTE]
