Stereo and Speaker questions
Another thing that I plan on doing in the really near future is to upgrade my speakers and stereo in my truck. I've got a 1982 Ford F-100 XLT Lariat with an original AM/FM radio and door speakers.
I'm planning on installing some 6.5" 3 way coaxial speakers in the doors and a media player head unit for a stereo system (no CD). Pioneer makes a pretty nice one that's inexpensive. I'm not doing any subs or amps. Just want some decent sound from the system.
My first question: What is the max depth a door speaker can be for these trucks?
My second question: What is the max distance from the speaker to the grill in the door panel?
I'll be removing the door panels in the near future to install some new window channel/scrapers but I'd like to know now so I can go ahead and order some speakers for the doors..
I've searched but not found anything on the depth or distance to grill...
Thanks ahead of time!
I'm looking to upgrade my stereo and speakers too...I'm pretty sure most 6.5's will fit the door...as long as they don't have the extra plastic housing on them...otherwise you will have to cut out the door panel.
What model is the head unit your looking at...I was thinking of just ordering a cheap one from Walmart (Boss)?
My dash already has a vintage 80's Pioneer tape unit (seen better days) in it...so the decision to cut or not to cut has already been made for me.
Not all 6.5's will fit... the depth is around 5" if i remember correctly which is plenty for most basic setups. But i would do yourself a favor and just take the door panel off, take out the speaker, and measure the dimensions yourself. Then once you find a speaker you like just look at the specs.
I also decided to get some of the Boss 300 watt 3 way 6.5" coaxial speakers. They got pretty good reviews as did the deck also.
I actually went cheap. I went with a Boss media receiver.. I think it's a Boss 612UA. Got it at Walmart for $35. It does not have a CD player, but has the 3 things I was looking for... Mechless (No CD), USB, and has a clock. I'll upgrade it eventually so I went cheap for now. Would rather spend my money on other premium parts for my truck!
The stereo is small. It's only about 4 inches deep. It's light, but not cheap light. It feels pretty good.
The only issue I have is that if you are cutting up your panel to make an aftermarket stereo fit, you'll have to add some filler or something to make it work. I have an idea as to what I am doing but not sure if it will work.
Here's a pic of the single DIN sized bracket against the original panel.
As you can see, the original stereo was much taller..
Thanks!
