Temperature 300 Inline 6 - Ford Truck Enthusiasts Forums
Old 07-22-2003, 01:53 PM
ocean_461 ocean_461 is offline
ocean_461 is starting off with a positive reputation.
Found this forum trying to research a potential problem.
'86 Ford F150 with rebuilt 300 I6 with about 5k miles on it now. Everything was replaced. New water pump, fan clutch, hoses, thermostat etc. Radiator was rodded.
To me it runs too hot. But I am not sure what the safe temperature range is. I finally put a mechanical temp gauge in this weekend.
I live in Arizona and it is summer. Winter comes around and I probably wont have any issues. Here is what is happening. First got the truck and noticed the the gauge runs right at the 'R' in normal. Never seen it there with the old motor. When hot outside and sitting at a light for a couple of minutes, the gauge would go to th 'A". I go into panic mode: turn off air etc and get moving again and the gauge goes back down. I immediately suspected the fan clutch. Mechanic says it is fine. So I put in a mechanical gauge to get some hard numbers. Runs between 190-200 during normal driving. Get on freeway goes to 210-212. Everything is fine. Get off freeway back to normal traffic, fluctuates between 210-215. Ok. Stop at light for 4 minutes, goes to 230-235. I don't know if it would go higher than that because I start to panic and get moving again somehow and it comes back down to 215.
Are these normal temperatures for the summer? 230 at a light? Seems to high. Nothing else seems out of the ordinary when that hot. No steam or pinging or things like that. The motor is a little noisier but that's it. I took it to the mechanic but I no longer trust him. He said he ran it for two hours with the air on and it never got above 214. I now know that's not true with the new gauge.
Is 230 too hot or not?
Wow, long first post. Thanks in advance for any wisdom you can share.
jason
Old 07-22-2003, 06:20 PM
javi2001's Avatar
javi2001 javi2001 is offline
javi2001 is starting off with a positive reputation.
1 Replace T-stat from actual 192f opening point to 180f.
2 My I6 towing 1.100 pounds, in city trafic with AC and external temp around 90f never gets more than 215f
3 Standard Fan cluch engages about 210f or more it seems to me to high so I had replace the thermic spring in front by that one used on Carburators climatic control, then now it engages about 180f
4 Iff temp gets 225 or more is very high, don't let it get more than 220.
Regards;
Old 07-22-2003, 10:18 PM
skidj0003 skidj0003 is offline
skidj0003 is starting off with a positive reputation.
Had a similar experience after I rebuilt a 351W. Turns out that a freshly built engine has more internal friction which generates extra heat. I did not have the coolant passages cleaned which reduced the transfer of heat. Had the radiator "rodded", but it was not efficient enough. I eventually had a new radiator core installed and the problem was eliminated.
Old 07-23-2003, 01:42 AM
Redneck-Cowboy's Avatar
Redneck-Cowboy Redneck-Cowboy is offline
Redneck-Cowboy is gaining momentum as a positive member of FTE.
I'm happy if my 86 F-150 4x4 300 stays around the "orm" in normal, before I flushed the raditor an replaced the defective thermastat it used to be pushin L and sometimes blow water out the overflow.
Redneck-Cowboy
Old 07-23-2003, 07:39 PM
serving_time serving_time is offline
serving_time is starting off with a positive reputation.
If you have a new t-stat, they can run high for a while. I put a 192 stat in my truck, and at new it would run at the r of normal. After a little time, maybe a month or so, it is down to running at the N of normal. Anything over 210 sounds a little high. Over 220 IS HIGH.
Old 07-24-2003, 06:49 PM
javi2001's Avatar
Sometimes I6 is litle hard to relase air inside water system, so thats the reason after any repair on cooling system it will run a bit hot for a couple of days.
Regards;
Old 07-25-2003, 01:16 AM
MEPR MEPR is offline
MEPR is starting off with a positive reputation.
it probly shouldnt run much hotter than 190-200*. I would sugest putting a colder T-stat in the motor.
Old 07-25-2003, 07:06 AM
socket40 socket40 is offline
socket40 is starting off with a positive reputation.
just a thought,is your fan on the fan clutch the right way? had one come in the shop the other day with a fresh motor that was running hot,found that the fan was on backwards.
Old 07-25-2003, 03:36 PM
83Van's Avatar
83Van 83Van is offline
83Van is starting off with a positive reputation.
Never had overheating problems, but the "dealer installed" AC didn't do much in city traffic. Last summer I replaced the stock belt driven fan with a Flex-a-Lite dual electric fan...big difference in two ways: First the AC works fine all the time, second it freed up a small but noticeable amount of power. The heater, another weak point, also works better in the winter since I can turn up the cut-in temp of the fans. In a full size van you need every bit of heat you can suck off that Pinto sized heater core.
Old 07-26-2003, 02:36 PM
DEPGrunt DEPGrunt is offline
DEPGrunt is starting off with a positive reputation.
Unhappy Temperature 300 Inline 6
Let's not forget that you're in the middle of the desert. A thermometer left in direct sunlight in my home town will hit 125-130 every single day in July. The air passing over my radiator doesn't want to accept much heat in the first place, plus it's less dense.
I flushed it out, put on a new radiator, T-stat, and fan clutch, and that took me from boiling over to R/M in Normal. Lucky for me the Canadian tourists all leave by May, so there's no traffic when it's hot.
I did just go look under the hood though and I had an idea. The fan isn't centered on the radiator, and it's a tad small to begin with. I bet that thing flows almost zero air through the left side of the radiator (thanks to the shroud.) Placing a larger electric fan centered on the radiator (with a new shroud), should help.
Old 07-27-2003, 02:19 AM
rwr rwr is offline
rwr is starting off with a positive reputation.
I live in carlsbad nm avg summer temps now avg around 110 to 115 have had my 83 here since it was new temp gauge at idle runs 220 all day drops to about 195 when i move, with or without the ac it does not change, even added a oil cooler( mines a stadard) didnt change anything, mechanics told 230 and below isnt a problem for this engine
Old 07-28-2003, 09:47 AM
Seems I may have had a radiator cap problem. I was checking things Saturday morning and pulled the cap off and it didn't feel right coming off. A little loose. It was the right one and showed no signs of cracking or other wear. It just felt weird, I don't know how else to explain. So I just replaced it. It's only $5. Well, It seems to have made a difference. 10 degrees or so. I've only had one long drive for the test but I am opptomistic.
Same 30 mile drive, 25 of it freeway. Warms up to 190 and after about 10 miles it has creeped to the 200-204 range depending on speed. Exit freeway at light moves to 205-207. Get moving again and it goes back to the 200-202 range. After two miles or so of the slow in town speeds it is around 198-200.
Looks good to me. Thanks for all the suggestions. We'll see how it shakes out.
jason
Flushed cooling system in the summer, got no heat in the winter...? Chiver Ranger & B-Series 16 02-06-2017 06:12 PM
High oil temp and gauge issue mdelfunt 6.0L Power Stroke Diesel 50 08-07-2016 10:13 PM
95 460 overheats on freeway justin90gsx Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 37 08-15-2015 11:25 AM
Oil Coolant Delete - Whats new? Jeremy2792 6.0L Power Stroke Diesel 8 06-22-2015 08:22 AM
Correct Temperature Gauge Reading? Mike in RI Explorer, Sport Trac, Mountaineer & Aviator 15 12-27-2004 03:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
