timing gears and chain?????
are the timing gears on a 351 c and 351 m the same? trying to figure out what would have caused new gears and chain to break.auto store may have given me wrong gears and chain.???distributor gear is shredded but cam gear looks ok. getting air pushed out the #1 cylinder but when i turn the motor cam gear doesnt move?W.T.F????
JUST PUT A NEW DISTRIBUTOR IN ABOUT 6 MONTHS AGO AND THE GEAR LOOKS LIKE ITS BEEN SLICED UP NOT SMOOTH TRUCK JUST QUIT RUNNING AS I WAS DRIVING.ROTOR DOESNT TURN.TURNED THE MOTOR BY HAND AND CAM GEAR DOENT MOVE.FIGURE THE TIMING CHAIN BROKE AND I JUST REPLACED GEARS AND CHAIN NOT TOO LONG AGO
It's been a while since I did a timing chain in my 400 so feel free to correct me if my comments are off. I think you might be able to touch or possibly see the timing chain through the fuel pump lever hole so it might be worth while to take the fuel pump out to have a peek. Maybe the crankshaft timing gear has broken in half???
I once had the oil pump in my 400 pick up a piece of crud--it was enough to shear off the roll pin in the distributor gear. I found out from a Ford dealership mechanic afterwards that this was something that would occasionally happen--first (and only) time for me.
Jonathan Page
03-26-2014 12:37 PM
chrono4
01-26-2005 09:51 PM
JRProaudio
12-16-2003 07:42 PM
