Is this normal wear on the ring & pinion gears?
Good thought! Thanks!
I just did a quick price check online, and it's about $30 bucks for the U-joint and a strap kit.
I think I'll toss that in there just for grins, and see what I get. Even if that does not get rid of the vibration, I'll want new u-joints if I replace the axle anyway....
It'll be two weekends before I can get to it, but I'll try that and report back.
Well, the job is fianlly done. Sort of.
The good news is, the rear u-joint was definitely bad, and I'm 98% sure that was the whole problem.
The bad news is that 2%. I have a new vibration that is entirely speed dependent. It does not get worse when under load, but increases with speed.
I'm thinking I managed to do something to make the driveshaft assembly unbalanced.
But what?
I'm not clear on how to make sure the rear u-joint goes back together centered. It's the kind that has two u-bolts to hold it in place. Could I have gotten that off-center?
But what?
Did you replace the front U-joint??
Did you turn the transmission yoke 180* to the drive shaft??
This alone would cause the drive shaft to be off OEM balance.
Did you replace the differential U-clamps with new ones??
Old U-clamps should never be re-used, as they become "stretched"
It's almost impossible to get the rear U-joint out of alignment with the differential yoke, as there are "nubs" on the yoke to center the U-joint.
Wow! Thanks for the very fast and very useful reply! I love this forum!
Oh, straps. I completely forgot about them!
Off to the store first thing in the morning!
As to getting it off 180*..... maybe. The new joints are greasable (yay!) after the new joints were back in, we found my grease gun had fallen apart. (Cheap Chinese junk, I guess.)
So I went off to town to get a new one, and left my two older sons to put the shaft back in. That was a mistake on two counts. They got it done, then we had to undo it to grease the front one. (Yes, I did get a new front joint.) Couldn't get to the zerk otherwise. That's when I found I had trouble getting the rear centered.
Of course, they had taken the van down off the jackstands, so I was doing the last part with not much clearance.
With some better room to work, and some new straps tomorrow, I'll take a more careful look at how things go together.
I hope that clears things up!
Then it will be on tot he IAC valve, and then the heater resistor.....
Success!
I got some new straps, and noticed that I had put the new rear joints in with one end riding on top of the nub that centers it. Got that corrected when I installed the new straps, and it's now smooth as silk. No more vibration, even under acceleration going up a steep grade.
I do get some just before the shift, but it's engine speed dependent, not vehicle speed, so it's not driveshaft or differential.
Thanks very much to all who contributed!
kc7smo
17
09-20-2016 10:39 PM
gcfisher75
01-23-2007 01:19 PM
